Unread 07-21-08, 08:54 PM
JeffAxel JeffAxel is offline
you are a hopeful sort!! But if you can get to Portland, dinner is on me!
Unread 11-23-08, 03:59 AM
Tony
I am dragging this old thread out from the archives.....................has anyone had any new seat belt purchases? I am still looking and it sounds like the 3 point system would be sufficent. Thoughts?
I was just pricing shoulder harnesses out and Cessna sells a complete kit, including both lap belt and shoulder harness for both pilot and co-pilot, with all new hardware for around 300 dollars (Canadian).
IIRC, Cessna told me this kit fits all serial numbers.
Unread 11-23-08, 10:37 AM
tropical tropical is offline
Originally Posted by Tony View Post
I was just pricing shoulder harnesses out and Cessna sells a complete kit, including both lap belt and shoulder harness for both pilot and co-pilot, with all new hardware for around 300 dollars.
n ypu
Can you provide more information, such as part number or kit number?
Unread 11-23-08, 12:27 PM
Tony
I will get the kit number and post it tomorrow.
Unread 11-24-08, 09:34 AM
Paul462 Paul462 is offline
Wink
Herb,
Mary & I have flown 1968 T337C's with BAS inertial reel shoulder restraints for the last 6 years, and they're comfortable for me. Mary complained of them rubbing against her neck, so she made little sheep skin sheathes which attach via velcro, and now finds 'em comfortable. If you're around 6 feet tall, they should be OK.
Apparently BAS got the STC for T337C's during recent years, so they can now be installed on that basis. They're inertial reel - a definate advantage over non-extending shoulder harnesses, and have two straps, which is probably better than one diagonal strap at preventing one's upper body from going through the instrument panel on impact. Is the Cessna kit inertial reel?
Paul & Mary
Paul
T337C
Unread 11-25-08, 02:27 AM
Tony
Service kit number is sk337-55a2. Double check with Cessna for applicability. This is pilot and copilot seat. No inertia reel as far as I know.
Unread 11-25-08, 06:58 AM
The inertia reel seat belts are about $600 each from Cessna.
Pete
Unread 11-25-08, 11:22 PM
We have 4 sets of seat belt/shoulder strap for skymasters. ( A set is pilot and copilot)Will let them go some what cheap.
Kim
Unread 11-26-08, 03:46 PM
Kim
Sent you an email on this.
Unread 01-11-11, 02:55 PM
Learjetter Learjetter is online now
FYI: Airbags and Shoulder Harnesses
Resurrecting an old thread...Just FYI: NTSB recommends requiring GA aircraft to have shoulder harnesses/airbags--two years after you folks discussed their benefit here, on this board!
Links for more info:
http://www.basinc-aeromod.com
http://www.faa.gov/aircraft/gen_av/harness_kits/
NTSB News Release below (Jan 11, 2011):
NTSB PRESS RELEASE
National Transportation Safety Board
Washington, DC 20594
FOR IMMEDIATE RELEASE: January 11, 2011
SB-11-03
NTSB STUDY SHOWS THAT AIRBAGS CAN PROVIDE OCCUPANT
PROTECTION IN GENERAL AVIATION ACCIDENTS
Today the National Transportation Safety Board adopted a
study that concluded that general aviation (GA) airplanes
equipped with airbags provide additional protection to
occupants in accidents involving survivable forward impacts.
Airbags are designed to mitigate head and upper body
injuries and are installed in the lap belt or shoulder
harness portions of the restraint system. They were first
approved for use in the pilot and co-pilot seats in GA
aircraft in 2003. Currently, there are nearly 18,000 airbag-
equipped seats in over 7,000 of the 224,000 GA aircraft in
the United States.
"Although airbags have been mandated in automobiles for over
a decade, the aviation industry has no such requirement for
small aircraft," said NTSB Chairman Deborah A.P. Hersman.
"The good news is that over 30 manufacturers have stepped up
to the plate and offer airbags as standard or optional
equipment."
The study, which examined 88 accidents involving airbag-
equipped airplanes that occurred between 2006 and 2009,
found no instances where the airbag caused harm in properly
restrained occupants. In addition, the study found 10
survivable accidents in which the crash forces were severe
enough to cause injury and/or to deploy the airbag.
Within the group of 10 accidents, 12 occupants experienced
airbag deployments, and the study found that the airbag
likely mitigated injuries for two of the occupants.
The study also noted that there were no negative
consequences as a result of airbag deployments. For
instance, there were no cases in which the airbags were
expected to deploy but did not. Nor were there any cases
that involved airbags deploying under unexpected
circumstances, hindering egress, fueling post-crash fires or
interfering with rescue attempts. Yet investigators did
uncover some safety issues with restraint systems.
One such issue involved the incorrect usage or adjustment of
seat belts. In certain aircraft types, the seat belts in the
left and right seats can become reversed, which could result
in the wrong airbag being activated if only one of the seats
is occupied.
There were also concerns with optimal airbag protection for
occupants whose body mass indexes (BMI) classified them as
either overweight or obese (BMIs of 25 or higher). The NTSB
questions whether the airbag-equipped restraints were
designed and tested with the high-BMI population in mind.
An additional finding of this study was the strong
affirmation that correctly installed shoulder harness/lap
belt combinations provide significantly greater protection
in GA accidents than that offered by a lap belt alone. Based
on an analysis of over 37,000 GA accidents, the Board
concluded that the risk of fatal or serious injury was 50
percent higher when an occupant was only restrained by a lap
belt as compared to the combination lap belt and shoulder
harness.
"The simplest and cheapest improvement to the safety of
general aviation aircraft occupants is the mandatory
installation of shoulder harnesses," said Hersman.
The five-Member Board voted to adopt six safety
recommendations, all directed to the Federal Aviation
Administration:
1. Require manufacturers to modify restraint systems
vulnerable to being used incorrectly in newly built GA
airplanes and to modify restraints in existing airplanes.
2. Revise the guidance and certification standards for
restraint systems to reduce the likelihood of misuse.
3. Modify the guidance to GA airbag manufacturers as to how
they should demonstrate that an airbag design provides
adequate protection for a greater range of body sizes,
including very small and very large individuals.
4. Require the retrofitting of shoulder harnesses on all
general aviation airplanes that are not currently equipped
with such restraints.
5. Evaluate the feasibility of requiring airbag-equipped
aircraft to capture and record crash dynamics data to
determine whether the system performed as designed.
6. Develop a system to track safety equipment, such as
restraint systems, airbags, and aircraft parachutes,
designed to improve crash outcomes.
The complete safety study will be available at www.ntsb.gov
in several weeks.
Fly safe!
