Old 05-07-02, 05:28 PM
Wayne Pearce Wayne Pearce is offline
Wayne Pearce is an unknown quantity at this point
Fuel Caps
I have '73 337G normal asp
I still have small amount of anti corrosion stuff leaking from root of wing when Left hand fuel tank is filled (probably happening when fuel expands and leakage washes small amount of anti corrosion stuff down inside of wing)
What I have found so far !
I blow into wing tip vent and can hear the fuel tank expand, I block off vent and it seems to hold pressure, I let it go and it takes quite a while to release all the pressure, obviously it takes a number of puffs to build up this pressure. you can also sense the difference in air flow from pressure in to suck out (brave huh)
The fuel caps have a neoprene cap seal which seems in good order, the caps also have a neoprene red flap valve which seems in good order. This leakage only happens overnight when a/craft is stationary. And the only evidence is a discolouring residue.
Assumtions so far !
The fuel cap vacuum valve seems ok
The fuel cap seal seems ok
The fuel tank seems ok
The vent check valve seems ok
The line from wing tip vent to fuel tank seems ok
Is there a separate overpressure drain line somewhere or is there a tank filler area drain line that I have missed
any suggestions would be appreciated...... best regards.....wayne
Old 05-08-02, 02:11 AM
GMAs GMAs is offline
George M. Amthor, Jr.
Wayne your problem is either a crack or one of the gaskets which are under either the fuel senders or inspection covers... if in fact it is leaking only when you fill them all the way up... then I would suspect that it would be one of the gas guage sender covers... their I would look for staining around when full... and you should see it by removing the cover... 4 screws... and looking at them when the tanks are full... they are kinda weeping leaks...as the gaskets get dry and old... so they won't be streamers...
It is also dye in the gas not anti corrosion stuff... smile... good luck GMAs...
