Unread 08-08-05, 09:21 PM
gcball gcball is offline
Member
gcball is an unknown quantity at this point
Angry Fuel Selector Valve Rear Engine
Last year I had my rear engine rebuilt for my t337b, with new everything. During the rebuild the mechanic notice that aft fuel selector valve had corrison and recommended that since it was original to send it out for rebuild, I reluctantly agreed (it worked fine). After about twenty hours on the new engine a month ago I noticed a fuel flow problem on the rear engine when switching from to the aux's (cruise flight at 7500). A couple of minutes in to the aux's tank (rear only) and the fuel flow started going erratic from 13 to 5-6 gph. Boost pumps would not always fix the fuel flow problem but, switching back to mains would. This is only happening on the rear engine. After flight, mechanic/shop troubleshot and found that the new fuel pump for the rear was not up to par and replaced (in warranty), thought this would fix the problem. Two weeks later same scenario, flying at same altitude on mains and switches to aux's with the same rear fuel flow problem. Tried to troubleshoot pumps would'nt overcome problem, landed and had same shop troubleshoot again. This time they said it was the aft fuel selector not responding properly and sent it to B&S for eval/repair (by the way, B&S Repaired and Certified this same aft selector in May of last year-see above). I have since sent it back a third time and apparently B&S although they charged $90 for bench tests did'nt test it and said they would'nt charge our shop for the test. My question is, is this the fuel selector valve completely? I have seen the valve and understand that it's pretty simple but, tomorrow will be the third try to get the valve to work properly (last time we could'nt get it to shut off). Are these valves tricky, how about the linkage, any tricks to setting up. I'm spending (and hope to recover) a lot of labor hours taking this out and putting it back only to be in cruise flight with my family to find that when switching for the mains to aux's the rear engine wants to quit. Any thoughts?
Thanks in advance,
Gavin Ball
T337B-0637 a.k.a Tweetie Bird (Third generation in this plane)
Unread 08-09-05, 08:44 AM
Dale Campbell's Avatar
Owner 337H N337DC
Fuel Valve Problem
Maybe it is not a fuel valve problem. Check the vent on that aux. tank. If the vent is blocked you would get that same problem. On some tanks the vent is a small hole in the cap, and a little bee loves plugging that hole with mud or, it could be corrosion at the hole. Check out were the vent is and is it open. Just a though, good luck. Dale Campbell
Unread 08-09-05, 09:19 AM
Given the design of the fuel selector valve and how much attention it has received, maybe it's something else. Two thoughts: is there any clogging in the fuel line between the fuel selector valve and the rear engine (including the outlet of the auxiliary tank), and is there proper venting of the auxiliary tank?
Unread 08-09-05, 12:08 PM
Member
Cool
Thanks for the suggestions, I'm calling the shop now to pass on your recommendations.
Gavin
