Unread 04-28-05, 01:59 PM
Dale Campbell's Avatar
Owner 337H N337DC
Rough engine at low RPM
I had problem like yours. I have a normal asperated 337H that would run rough at low rpm and would just die out on some landings, that was 5 years ago. I took it to a old O2 mechanic
from Vietnam and he fixed my problem after having it to 3 other shops. He put a set of gauges on the fuel pump outputs and ran them back to the pilot seat to watch at differant RPM and adjusted the high and low pressure output at the pump. That solved my problem. I have flown my 337 for 5 years and all is now fine at all RPM. He worked out of Bloomsburg, Pa. the last I knew. Dale Campbell
Unread 04-28-05, 02:47 PM
You can go to the TCM website and download the TCM Service Bulletin 97-3b. It explains all of the fuel setups like your good mechanic accomplished!
Setting the low pressure reading to the bottom of the low-pressure range and high pressure reading to the top of the high-pressure range seems to give excellent results.
Walter Atkinson
Advanced Pilot Seminars
Unread 04-28-05, 07:09 PM
Member
sometimes when the pressures are correct and it still runs rough, look for leaks, these planes are old and a lot of "o" rings are getting very hard and loosing sealing abliity, sucking air can show up as fuel stains. at higher settings an abundance of fuel is flowing into the system thereby making the leak/sucking air of little consquence. however at reduced power settings they can make a substanial impact as the quanity of fuel flowing in the system as it is much lower allowing the leaks/air sucking to super lean or starve it till it quits
Unread 04-28-05, 07:36 PM
Member
[title removed by webmaster]
[comment removed by webmaster because I don't need any more email storms in my life...]
See you in Key West.......
Unread 04-28-05, 09:40 PM
hewilson hewilson is offline
Member
hewilson is an unknown quantity at this point
Running Rough
[Removed by webmaster. However benign, please comment about the airplanes folks, not the people. Thanks.]
Hugh Wilson
Unread 04-29-05, 01:44 AM
Member
Rough Engine
Roger. Copy that.
Hugh Wilson
Unread 04-29-05, 09:30 AM
Big AL is right. Leaks whether fuel or air WILL cause these symptoms. If it's leaking either, it's no longer a conforming engine. Non-conforming engines don't run as well as conforming ones! <g>
Walter Atkinson
