Old 01-05-05, 09:25 PM
337G 337G is offline
337G is an unknown quantity at this point
type differences
Can some one explain the difference between an F model and a G model.
Thanks in advance!
Craig B.
Old 01-05-05, 11:49 PM
Yow! I assume you are talking normally aspirated for both? This is the biggest model break in the history of the line. There are lots of differences, but here are the ones I can think of offhand:
Interior: F has six individual seats, like a 206. G has bench seat for middle row. Non-P G model still has six seats, but P model has only five. Non-P model has baggage door, P model does not.
F has conventional Cessna door, like 206. G has air stair door, even on non-P.
Gear actuated with electrohydralic power pak in G, F is engine driven pump on one engine (or optionally two pumps, one on each).
Front exhaust is different.
Pitot tube mounted inside left wing strut.
Fuel system: F: Aux and main tanks, see www.skymasterus.com for excellent article on this fuel system. G: all tanks in each wing interconnected, so fuel is either on, off or crossfeed.
Fuel guages are float in F, capacitance in G.
Wing tip lights are flush.
Empty weight on F is lower than G by non-trivial amount. G has structure in it (like the airstair door) that is common with P model, but not really needed.
I think the aluminum wiring started in the G, but I am hazy on this.
There was an AD on F and earlier models to remove the soundproofing in the cabin. The material used was causing corrosion. Please check to make sure I have this one right as well.
I think the alternator warning system changed to idiot lights between the F and G models.
I think there are lots of other differences, but I probably got most of the major ones.
Anybody have some more to add?
Old 01-06-05, 07:54 AM
The front propeller is longer on the G
Old 01-06-05, 04:26 PM
G model normally aspirated has NO baggage door.
Fuel system article for F model is at www.skymasterus.com (ends in .com not .org)
Old 01-06-05, 06:28 PM
Thanks Ernie, I fixed the link to your site.
When did they add the baggage door back, if not 1973? Or was it an option? I have been in a late model normally aspirated that had a baggage door, but I think it was later than '73. It was stock, not a mod. I really noticed because P models don't have them, and I was envious...
Old 01-12-05, 10:05 AM
Cessna added back the baggage door on the "H"'s, normal asperated.
Old 01-12-05, 12:29 PM
Thanks. Nice to know I was not halucinating.
Old 01-12-05, 05:08 PM
F vs G
F model pilots left window is an emergency exit. Also, I believe that if the G model does not have a baggage door or other emergency exit, by FAA rules it can only have 5 seats. Anyone out there have any knowledge if that is the case?
Jerry
Old 01-12-05, 06:49 PM
Re: F vs G
Jerry
That's true only if the aircraft is pressurized. The non-pressurized "G" is certificated for 6 seats since the pilots side window is an emergency exit, the pressurized version is certificated for 5 seats.
FAR 23 has a paragraph that says if the aircraft only has one entry/exit, its limited to 5 seats.
Old 01-13-05, 06:53 PM
My NA "G" has a baggage door (Added after factory I think), with inside handle, no pilot's escape window. Am I legal to add 6th seat?
Old 01-13-05, 08:30 PM
EZCOPE EZCOPE is offline
EZCOPE is an unknown quantity at this point
Cool
Seats and exits - my understanding that six seaters required emergancy exit pilots side, otherwise limited to five seats. Baggage door on later models as an option(?).
