Unread 04-02-03, 03:57 PM
amichelin amichelin is offline
Member
amichelin is an unknown quantity at this point
Unhappy broken altimeter
Hi
I have a 1973 T337GP (79C) My encoding chip broke in my arc encoding altimeter (42540-3128) and they want $900 to fix. Any suggestions? anybody have a spare that they want to sell, any shops that will fix for less? Is there an altimeter that will swap out the broken one? Any help at all.
Adam
Unread 04-02-03, 05:22 PM
Lightbulb
I may have what you need. Mine is a part #42540-2128. It was last certified 04-30-01 and was removed during a complete panel upgrade. Give me a call @ 559-791-1866 ask for Dave Farrar
Unread 04-02-03, 06:37 PM
Member
hope is in the air
Hi Dave
What year did the altimeter come out of? does anyone know if the 2 are compatable?
Adam
Unread 04-03-03, 09:07 AM
Bob Cook Bob Cook is offline
N69S
encoder
Why not install a blind encoder for 150 dollars. Forget about using the built-in encolder.
Bob
Unread 04-03-03, 10:13 AM
Member
blind encoder
Hi
Thanks that is an option. I am planning to upgrade my panel within the next 6 months. There is not alot of room behind the panel. If I cannot find a replacement that is exactly what i will do.
Adam
Unread 04-03-03, 10:27 AM
Lightbulb
My EA-401 encoding altimeter was removed from S/N P3370204.
The service parts manual for the EA-401A & EA-801A shows that the -3128 and -2128 are both unlit, 28volt, and the baroset window is in.Hg.
Dave Farrar
Unread 04-03-03, 01:35 PM
N69S
re encoder
The ameriking is very small and can be placed almost anywhere. I use one as a second encoder with a second transponder. This one is far easier to calibrate.
fyi
bob
Unread 04-03-03, 03:03 PM
Member
small
Hi
Took a look at the unit, very small indeed. The are retailing for $160 new plus connectors and ifr certification.
Adam
