Unread 12-28-23, 08:39 PM
YankeeClipper's Avatar
Just thought I would point out in this thread, as I believe I did in another, that Rob Air repair in Washington will do an exchange or repack your own serviceable swivels. As of this year he's charging 500 each, with $1,000 core if yours is not serviceable.
Unread 01-05-24, 06:21 PM
rmorris rmorris is offline
Ovh on own?
So the early part of thread was encouraging...rebuild your own very easily for 75 cents, then devolved to send off for $500/ea.
Has anyone rebuilt their own? If so, do you have a list of p/n for each part needed and/or other kit?
Unread 01-05-24, 09:16 PM
Joes Joes is offline
two different approaches
Brake line swivel fix in search
Unread 01-05-24, 10:44 PM
Well it's better than paying the going rate for these new ... after you've sweat for 3 days wondering if such a unicorn exists. My recent sweat indicated to me that it's just a unicorn.
I have absolutely no basis to verify the suitability of these part numbers, but if you're willing to give it a go as a few others have, the parts they used are:
"MS28775-010, be sure to lube it up alittle before sticking it back in. Then I replaced the larger O-ring that plugs into the landing gear block with MS28775-110"
Lube it up with what, you ask? 5606 maybe ... Maybe, or whatever Rob Air repair does was my my answer, before they bench test it for 3 days, guarantee the result, and invite me to put my family alongside it. For 500 each I went that route.
And if you think that is a devolution, just wait until the next time you shop for a replacement wheel, or better yet, a new brake caliper assembly (and you will). I hate to say it, but we are all flying Model T Fords that need to resemble the original product exactly as it was built. Whether we like it or not, at this point we are all restorationists--either the religious kind, or the ones that bring ancient pyramids back to life. Your choice.
