Unread 10-23-23, 09:55 AM
OK, I used Snipping Tool in Window which cuts down on the original picture size. Here are the pictures.
Karl
Unread 10-24-23, 12:16 PM
Love the memory foam, or whatever that black stuff is. Great way to protect the airplane. Where did you find it?
Unread 10-24-23, 12:21 PM
Here is how you can make your photos appear inline in the forum instead of as an attachment:
Name:  How to show pics inline in the forum.JPG
Unread 10-28-23, 11:38 PM
I ordered it off amazon "Foam Rush 6inch x 18 x 20 High Density Upholstery Foam Cushion". The lift is a "Powerbuild 2-ton triple lift floor jack", I like that it has a safetly feature of placing a metal rod when lifted up, just in case the jack hydraulics fail.
Karl
Unread 10-28-23, 11:44 PM
Kim,
Thank you for supplying the pressure for the strut. Lifting the nose off the ground and charging it to 35 psi, gives it 3 finger widths when back on the ground. I had to use air. I bought a nitrogen bottle, but I think the regulator and hose I bought are the wrong type. I think I bought one use mostly for welding, what I need is one used to fill nitrogen shocks (with a Schrader value adaptor). I have to do more research to find one. In the meantime, here is a picture of the charged strut. Thanks to everyone who helped with information.
Karl
Unread 04-08-24, 09:12 AM
Learjetter Learjetter is online now
Nose strut access panel
Late to the party here, but I recently serviced my nose strut on my '77 NA G model and found that there is an access/inspection panel just behind the nose gear door on the aircraft belly. It's not a large hole, and you have to unbolt the lower door to get the panel off, but it is large enough to get a wrench and hose etc in there and makes replacing the valve stem, valve core, and strut servicing a little easier than going through the front side.
-YMMV-
--LJ
