Old 01-25-23, 12:01 PM
Crankshaft Seal Sealant
What is the proper sealant to use during installation of the crankshaft seal for a TSIO-360CB?
My overhaul manual is not helpful. A Continental Service Bulletin is only marginally more helpful, stating only "Apply a thin coat of Permatex to the O.D. of the seal." Great, but Permatex has a bunch of products.
I did a search here for 'proper sealant to use on crankshaft seal' and got:
'The search term you specified (for) is under the minimum word length (4) and therefore will not be found.'
I admit, it's been a while since I learned how to count, but I'm pretty sure that's more than four words. I get that reply a lot.
A search of the Web shows people using Titeseal and Dow 717. Some people say use a non-hardening sealant some say use a hardening sealant. I just want to use the proper sealant and not experiment.
Old 01-25-23, 12:23 PM
GearUp GearUp is offline
Sorry, I don't have an answer to your question, but do have a search tip. The best way I've found to search SOAPA is by using Google with a "site" filter. Prefix your search with "site:www.337skymaster.com" then add the search words.
Ex: "site:www.337skymaster.com crankshaft seal"
Downside of this method is the index seems to be about 6 months behind.
Old 01-25-23, 01:55 PM
Thanks for the tip. No luck this time...maybe the subject hasn't been discussed before.
Old 01-25-23, 09:03 PM
I’ve used pliobond it’s a contact cement like 1300L or yellow glue probably get a can from spruce
The permatex is the aviation form-a-gasket or it use to be #2
Old 01-26-23, 06:47 PM
Thanks, Kim. The Aviation #2 sounds pretty official, and even Wally World carries it.
Old 01-29-23, 12:20 PM
The Continental M-0 repair manual has all the info on procedure and sealants to use, on the road and from memory…
Clean bore well with MEK, there is a spray primer that is applied, then the purple case half sealant goes on the bore, then the permatex brown liquid on the seal and install.
When I can I will get the actual numbers of the items.
Old 02-02-23, 11:30 AM
Thanks, Dan.
One sticking point is that the person who installed the seal retainer plates, 90 degrees off from what the parts diagram shows, did so when the sealant was still wet. I don't think they're going to come off without being bent. Good thing new plates are so cheap. Less than $20 each! :0(
Old 02-02-23, 11:42 AM
I am still traveling on the road, the plan is to be back home this eve at our airport, I can get the info tonight and will supply it.
Dan
Old 02-08-23, 03:50 PM
Dan,
I found the M-0 Standard Practice Maintenance Manual, thanks for the tip.
Rev 1, Change 3, dated Jan 2023 is the current edition, for anyone who needs to update, and here's a link to Continental's tech pubs.
https://www.continental.aero/support...e-manuals.aspx
