Unread 10-09-22, 02:04 PM
bigcheese
Free engine analyzer - zero install
I have been flying without and engine analyzer for 27 years.
Sure, I also like pretty things that go blinkety blink.
I confess I HAVE been thinking about it.
I see too many people get hysterical about one egt probe being 10F 'too high'
C'mon. These sensors are sitting in the flame off a torch.
Savvy has a nice article pointing out all readings are just averages anyways.
SO
On a trip from DC to 'Flarida and back about a month ago.
About 20 mins after takeoff, a slight vibration.
Subsequently disappeared.
Doing some math in my head...
First, round off the arithmetic for my own convenience.
(Like leaving a nice rounded $10 tip for a $42.68 bill)
So, let's call it 2400 RPM to make the math easy.
2400 RPM = 40 RP(Second)
In a 4 stroke engine power comes from 1 out of 4 rotations,
no matter how many cylinders...
So each cylinder fires about 10 times per sec.
So a slight 10 hz vibration meant one cylinder (out of 24) was unhappy.
There was no 'morning sickness,'
Valves probably happy, sticking valve unlikely.
AND going directly into annual just after return anyways.
Borescope of all valves showed very happy little round pizzas.
Cleaned all injectors, all happy happy.
Did I just save myself $12k on an engine analyzer?
(The 790 appeals to me anyway...)
Unread 10-10-22, 01:27 PM
A smart, thoughtful pilot like yourself would benefit greatly from a recording engine monitor. Once you have one, you'll wonder how you ever flew without it.
Unread 10-10-22, 02:13 PM
bigcheese
Engine Analyzer Options
The current best options seem to be:
JPI 790
Would fit nicely bottom of my avionics stack.
Maybe I unconsciously had it layed out that way...
Upside - 'Simple,' lowest installed cost ( I think)
Downside - A ton of wires from engines, but sufficient to do the trick.
The other option
Suite of EI CGR units to replace EVERYTHING
Two CGR 30P, one for each engine, replace MP and RPM
and a CGR30C where Shadin is, to replace everything else
The appeal to EI is a hub in each engine and minimal wiring from there to gauges.
Going through an extensive annual 'wallet-ectomy' this year,
and replacing the last window (front)
because it's not as nice as all the other ones which are new 'solar grade'
Unread 10-10-22, 03:11 PM
GearUp GearUp is offline
JPI 790
The other option
Other than grossly exacerbating the "wallet-ectomy", is there another reason a pair of Garmin GI-275 EIS gauges didn't make your best options list to replace everything? They're at the top of my list, but now I'm worried I'm not smart or thoughtful enough.
Unread 10-10-22, 04:17 PM
bigcheese
Gi 275
Good catch! I handn't thought of those.
Looks like $8k for the two displays, plus install.
One for each engine.
Even handles 4 tanks.
Hmmm.
Interesting.....
I see an STC to install,
but do they officially replace need for existing fuel gauges?
Unread 10-10-22, 04:41 PM
I think a pair of GI-275 EIS's would replace everything engine-related, including the fuel levels on at least four tanks, and be STC'd as primary-- even on our Skymasters according to the AML.
Unread 10-11-22, 05:38 PM
hayesjaj hayesjaj is offline
My family has 275s installed on one 337E and I'm doing another install now on my 337G.
They are excellent instruments but assume 10-13k all in after sensors and wiring. If you have capacitive fuel senders you'll need to change them to CIES as the cap versions aren't supported by the 275.
Cheers.
J
Unread 10-11-22, 06:27 PM
Good point on the CiES senders-- we did that during the last annual and it added ~13k combined for parts, markup & labor. Granted, a very significant chunk of that was removing and re-installing the Flint tip tanks as that's the only way to access the senders in those. YMMV. The CiES also require a dedicated ground wire, as I recall-- no big deal but maybe a bit more pricey since it is pressurized.
Unread 04-01-23, 12:39 PM
bigcheese
On the other hand INSIGHT G4 TWIN TURBO
This one seems to have everything, PLUS vibration analysis. Appealing to a nerd.
Skymaster kit around $6k + install.
Any experiences comments?
Not primary, which I guess the 275's would be....?
Unread 04-01-23, 05:36 PM
kbecker kbecker is offline
I have an older Insight model, the 1200, and have liked it. My complaints are related to its age--the technology to download the data is via some HP Palmtop.
Insight has fixed this with the newer models, plus you get fuel flow and vibration analysis.
In my 20 years with the 1200 I have had to replace one temp probe. Thats it.
Unread 01-06-24, 12:28 PM
bigcheese
Is that installed price for 2 G275s?
"My family has 275s installed on one 337E and I'm doing another install now on my 337G"
"Figure all in 10-13k"
Is that 'you' doing (two) of them, them" and just the price of parts,
or fully installed price by an avionics shop?
Unread 01-06-24, 12:39 PM
This is parts, at least was two years ago now with us doing the supervised grunt labor. The EIS kit and sensors will be 13-14k in parts now and CIES senders were 600 ea at the time, probably more now (i needed 4).
I’ve seen some breathtakingly high quotes for engine monitor installs recently, in the 30-50k range all in from avionics shops. Figure 200 hours in labor to be safe with a twin for this type of install.
Unread 01-13-24, 03:59 AM
YankeeClipper's Avatar
Now we're talking reality. About a year ago I got a quote for 35k, though I can't remember whether it was Garmin or JPI. They're comparable in cost in any case.
