Unread 02-20-22, 04:01 PM
Jhogan0101's Avatar
Engine oil on prop blades front & rear
Removed the props for some maintenance on the plane.
They sat on top of 5 gal buckets with studs pointed down for about 6 months.
Before they were reinstalled, the inner o ring (a1633-3) on each was replaced and props/crank were desludged with mineral spirits.
After reinstallation, the props now have eng oil (not red) on the roots of the prop blades on front and rear.
Any ideas as to why this is happening? Have run about 15 hours since reinstallation and still happening.
Models
D2AF34C59
D2AF34C61
337B
Philadelphia PA
Unread 02-21-22, 09:23 PM
Jhogan0101's Avatar
Today i put some duct tape where the prop flange meets the crankshaft.
After doing that i did a run up and no more oil on the prop.
I do remember when seating the new inner mounting ring (a1633-3) id did seem a little small but it is the correct part number. Also the correct thickness, i measured before installing (100 micron)
Next step is to remove both props and replace the ring again. Fingers crossed.
337B
Philadelphia PA
Unread 02-21-22, 10:25 PM
Was just looking. Manufacturer application chart for 337’s lists D2AF34 various. You have in your post D2AP34 model.
Unread 02-22-22, 07:36 AM
Jhogan0101's Avatar
Yes you are correct. That was a typo, i corrected it above thanks.
337B
Philadelphia PA
Unread 02-22-22, 07:47 AM
Service manual says definitely look at o ring in this situation. Also, isn’t there a second large o ring (possibly A1633-9)?
Unread 02-22-22, 09:31 AM
Jhogan0101's Avatar
I dont remember removing a1633-9 (73 in attached diagram).
I will order and see if its missing or leaking when i take the props off again.
https://ibb.co/pRvLk35
https://ibb.co/Q88p6zL
https://ibb.co/9vtKSnh
337B
Philadelphia PA
