Unread 12-24-20, 08:46 PM
hayesjaj hayesjaj is offline
Belt, suspenders and ladder? 3 artificial horizons? I'd go with just two (your choice for backup - elec or vacuum) and use a stratus/ipad as your 3rd if you REALLY want a 3rd.
So, here's my thoughts:
Primary will be the Aspen E5. Mostly, this is for the HSI, but eventually I will probably upgrade the whole thing to a MAX.
The AV20 is much more than an AI (although that could be very helpful). It does a bunch of air/data computations and gives density alt, TAS, and it will give me AOA and G loading. All for $900. Easy pick.
Last one is the original from Cessna. It needs to be retained until I dump the 400A autopilot, which will happen when A) mine breaks so badly it isn't worth repairing or B) one of Dynon Garmin or STEC decides to make available a digital AP.
Unread 12-25-20, 11:34 AM
Originally Posted by hayesjaj View Post
Thanks Rick that is a great help! Do you have any pictures of the cuts to the original panel available prior to installing the cnc'd cover? Also, looks like ours is almost identical. Would you mind sharing the CAD for the panel?
I would be interested in the options you picked for the MVP 50 as well.
Glad to help.
Just to be clear, my new copilot's panel is a clean sheet re-do, not an overlaid cover. Another thing to be sure of is the allowability of a panel material other than the original material. My original panel was made from a .050 sheet of 2024 T3, so that's what I went back with. My IA at one point made a comment the panel was "structural" which led me to believe that there might be specific requirements for the composition for the panel's material. You should check that out if you're thinking of changing material for your new panel's construction.
Here's a picture of the old panel prior to removal:
Old panel, installed
This is the picture of the old panel:
Old panel, removed
This is what was behind my old panel, after its removal: Note the brace I was talking about directly above the "FWD PASS AUX AIR" switch. Note as well, where my IA located the forward engine's EDC and sensors against the sidewall.
Behind old panel
I don't have the CNC file. I worked with a great guy locally who has all the equipment, and expertise, to do the layout, testing and cutting. If the frame of your copilot's panel is the same as mine (or at least close to mine), there might not be too much adjustment for him to layout and cut yours also. There, of course, would be some shiping back and forth until you got it the way you want it. He also, made all new placards and labels for the interior and made a new "Red Ball" for the handle of the emergency gear pump shaft, as mine appeared to have been broken into several pieces and glued back together several times. All of it looks great! We are working on new labels for the circuit breaker panel now. I'll put a photo below of this work in progress, but you'll be able to see the direction we're headed. His pricing has been very reasonable. I can get you in touch with him if you like, PM me and we can set a time to chat about his work, his contact info and all the options for you to consider in configuring your systems.
Work in progress on circuit breaker panel
Rick
N337K-FT337GP
KLOU
Unread 12-27-20, 02:17 AM
california Sky california Sky is offline
california Sky is on a distinguished road
Panel upgrade
Redoing our panel in 58C.
Looking to get as much input from others experiences as possible.
After about 5 tries we are almost there with the adjustments needed to get it just right.
Going with EI instruments as a primary replacement on the pilot side.
Will post pics in the morning
Unread 12-27-20, 10:11 AM
Are you doing the CGR-30P? If so, we should talk (and I would love to fly up from San Diego and see the project!). In addition to my 337 project, my brother/parents have a 337D and want to put a CGR-30P combo into it. Unfortunately, EI hasn't done an STC for us. Are you using a DER? Any chance you could share his info with me? I think I prefer the round gauges over the square (and significant panel mods required) for the mvp-50p.
Unread 12-27-20, 01:37 PM
EI product.
Did quite a bit of research and the EI product is well respected.
We are based at the old Norton air base would love to show you what we have done so far.
Still trying to upload pics maybe I can post a link to google drive of our progress.
Last iteration of the panel cut should be done next couple days.
Went with dual Aspens, kept the 400 autopilot which was sent out to Bevan for inspection / 8130.
Our plan is to have the 3 displays from EI on the pilot side where nav indicators used to live.
Feel free to contact us.
213-308-7077
Will keep updates going here for others to read.
Unread 12-27-20, 11:48 PM
New link for all to see
https://photos.app.goo.gl/hA8UqvGJZawfa1gz8
Unread 01-15-21, 01:49 PM
saxbill saxbill is offline
saxbill is on a distinguished road
Where did you put the other CGR 30-p? Any chance of seeing the major alteration FAA form and supporting data for getting it approved? Want to head down this same path very soon.
Unread 01-20-21, 12:21 PM
EI instruments
Still working on the layout.
No paperwork completed yet
Just got all the instruments situated last night.
Attaching pics after I create the link.
File Type: jpeg 45AE4144-5D9B-417C-BA11-F24D9B23FE68.jpeg (884.8 KB, 2358 views)
