Unread 05-08-19, 12:54 AM
Centered Power Centered Power is offline
Centered Power is on a distinguished road
Question Tech Questions from current Buyer of 337
Been Following Soapa for years - finally now looking to buy. Lots of reading already on SOAPA and manuals I have acquired: 1977 337G POH
1977 T337G POH
1971 337F POH
1969 337D POH
1969 T337D POH
1964 336 POH
Question 1: Both the 1977 POH show Gear Operating / Gear extended speed limit of 140 KIAS. I assume this is the same for 1973 - 1980 ?
The 1971 337F (last older fuselage style ) shows a Gear extension speed of 160 mph Indicated. This converts almost exactly to the 140 KIAS of later models.
HOWEVER -- The 1969 POH as well as comments in the one previous thread on the subject show a gear extended speed of 140 mph Indicated. I wonder if someone has a definitive answer for whether the difference between 140mph in 1969 and 160mph in 1971 represents a REAL change in physical structure, parts etc. ??? Also what is the number in a 1970 337E POH which I don't have ??
I note that sometimes aircraft manufacturers recalculated, weights speeds etc because of market pressure-- getting closer or right onto limits provided or implied in FAA Regs ---What is going on with this difference. ( It has some implications in my search and choice of aircraft to acquire.)
Question 2: This question regards the Robertson STOL--- I am aware that in single engine aircraft with the Robertson STOL that in order to achieve the Take OFF and Approach and Landing performance actually claimed, that one must fly the aircraft at VERY High Nose / Deck Angles ---The figures can be achieved in reality and the nose up in Take Off is extreme and just quite a bit higher than factory in Approach and Landing. SO the QUESTION is whether or not the Robertson requires the same technique in the 337 ? I am especially interested in the Approach and Landing and using both (each of ) the "Robertson Normal" and " Robertson STOL" technique.
These terms, Roberson Normal and Robertson STOL are on a Robertson publication I have in my possession --a 1 Page table which is info / numbers only for 337 models from 337A through 337G and T337G --- There is no date on this publication --But it is so old that Robertson was still operating at Renton rather than Everett where I first visited their Hangar in the early 1980's. (Obviously before Robertson death and sale to Sierra Industries.) --This Page about 337 performance says NOthing about Deck Angle / Pitch.
Thanks everyone for the help.
Unread 05-08-19, 10:59 AM
Gear Speeds
http://www.337skymaster.com/messages...ght=Gear+Speed
Unread 05-08-19, 12:47 PM
Question thanks for threads I previously saw, but..
Thanks for threads I previously saw, but.. actually I referred in my question to the fact that my query is NOT addressed in these threads.
I am not confused about Knots vs mph. I am not asking about the pre 73 vs the post 73 and am not asking about the distinction beween gear extension / retraction vs flying with gear fully extended down and locked ---- these are all quite clear in the various POH's and in the threads herein. -----NO the question --And my apologies if it wasn't apparent is specifically about the difference between 1969 POH and 1971 POH --140mph vs 160mph. All the other verbiage I included was my feeble attempt to show I was already aware of all the matters in the two threads referred to. (Also sme of the confusion addressed in these threads may have been exacerbated by the former change to GAMA "standard" POH.
Back to specific question:
WHY is 1969 POH different from 1971 POH: 140mph vs 160 mph ?
Both of these are pre 73 planes and pre GAMA POH format!
IS there a structural / Parts difference ?
Or was there a recalculation of mechanical stresses by Cessna ?
Or something else?
Thanks again -- also there is question 2 about Robertson above.
Unread 05-08-19, 10:08 PM
Cessna never made the same Skymaster throughout it's manufacturing process. That's why there is Straight, A's, B's, C's etc. models. They continued to make changes to try to market the airplane. The gross weights changed throughout the years also, it increased as the models increased. My personal understanding is because of marketing. They may have had to spend some money to add these extras (changes in certification) but it must have made sense to them to do it. The 1971 F model has the highest gross weight and therefore useful load too. It was the last of the swing door models and therefore had the latest and greatest stuff. Structurally, was it the same as the D as you asked? I am sure there must have been something to convince the FAA that the gross weight could be increased, what those are I am not 100% sure. But something justified it. The F model is the one to get if you can find one, rare birds. They only made 83 F models in 1971 and 64 F models in 1972. That is if you want a swing door model, but they were lighter planes and had the luggage door too. The 1973 and after got heavier and they eliminated the luggage door. There are some other differences to like the front prop blades are 2 inches longer than the rear prop blades. Why? To even the score on the single engine climb and ceiling for each engine. The rear was always better than the front so the solution was to put a longer blade on the front. Too bad because it really made the blade clearance close to the ground.
I have never seen any angle/pitch info on the Robertson STOL mod. Not sure it would be eas to do with all the models and differences that were made over the years. AOA would have helped back then but no one used those much for testing.
Hope that helps too
Unread 05-09-19, 12:20 PM
Landing Gear Structure
Centered Power,
My two cents worth - looking at my IPC (1965 thru 1969 Skymaster) you will clearly see there are differences in the structural components on the main landing gear bulkhead assembly (additional doublers after S/N 0526 for the higher gross weights, and even some different bulkhead channel part numbers after S/N 0610). Perhaps there are some more structural differences from after 1969 to 1971 that raised this gear speed number. To the normal eye (and even some trained mechanics) the structure looks identical, but Cessna, like all OEMs, made small changes to structure with small doublers or thicker webs and channels that strengthen up the structure. You would need to study the IPC between those model years. Sometimes you find some weird changes in the models based on marketing, however you have to be cautious when it comes to some things associated with limitations like speeds and weights - as there were subtle differences in the engineering to justify these changes such as small structural differences or flight control rigging differences to compensate for the different limitations.
Regards,
