Old 08-18-16, 07:06 AM
pilotpat pilotpat is offline
pilotpat is on a distinguished road
Insight Flow sensors onto an IO-360-GB
This is research for a G4 Twin engine monitor install.
Anyone have experience (and possibly pictures) of installing Insight Avionics flow sensors onto an IO-360-GB engine (337H)? Their website shows it to be (without fittings) 2" long in the flow direction x 1.77" (about twice that size once you add fittings and electrical connector) x 1.65" high. Best place I can figure to put it is under the alternate air scat hose with new inlet and outlet ho$e$, assuming the hoses can be prevented from moving. Insight details the sensor to be level with straight runs in and out to avoid turbulence.
Pat
Old 11-28-17, 05:09 PM
Did you find a solution
Hi Pat,
How did you make out on installing the flow sensor? I am getting ready to install the G4, and have the same question you do.
Old 11-28-17, 07:11 PM
Jeff, in the end we did not go ahead with G4 install but will at some time. The recommendation was to replace the hose going to the flow distributor with two shorter pieces and have the fuel flow sensor in the middle mounted inline "floating" with the hose which is properly secured by the installer, who hopefully has done such installs before. We also had difficulty figuring out where to connect the oil temperature sensor, which cannot replace the existing unit because the G4 is not a primary instrument aside from CHT/EGT. The avionics shop we talked to (BrantAero at CYFD) had a location they had used before, as the alternates suggested by Insight were blocked by the governor unit or did not exist on our engine.
Pat
Old 11-29-17, 03:42 PM
Sensors
Hi Pat,
Thanks for the quick feedback! I was wondering the same thing about the oil temp. I will need to sort that out as well I am sure.
Thanks for the help.
Old 11-29-17, 09:16 PM
FYI
on the IO-360 C I used the oil port just to the left of the crankshaft on the front of the block for oil temp. I would think your engine would have this port also. If not I would contact Continental Motor for info, they are fantastic to work with
Old 11-30-17, 10:08 AM
Thanks Herb! I will have a look at that on my engine.
This site is the best for sharing info - thanks to all.
Old 12-02-17, 09:26 AM
kilr4d's Avatar
kilr4d kilr4d is offline
Hi Pat,
Jeff, I have the G4 Twin (love it) and I'm piggybacking from the Shadin fuel flow transducers. I'll grab you a pic of the location tomorrow.
Regards,
John
_________
John K
1977 337G
CNC3
Old 12-03-17, 09:17 PM
Pictures
Thanks John!
Any pictures of the install are appreciated. I am planning to 'T' into the oil pressure indication from in the panel (at the Cessna gauges), but did you do something different? Any advice on any of it is appreciated.
Old 12-03-17, 10:00 PM
kilr4d's Avatar
Thanks John!
Here's the fuel flow transducers; the square aluminum boxes of course. They're plumbed into the main fuel line:
Front: https://imgur.com/lBRUW8q
Rear: https://imgur.com/y6EQVni
My oil pressure are taken directly front the crankcase; front of the engine not far from the propeller hub.
_________
John K
1977 337G
CNC3
Old 12-04-17, 05:40 AM
Thanks! Those locations should work for the Insight as well, and allow reuse of the existing hose for one of the legs. Is the white wire connecting to a temperature probe?
Old 12-04-17, 09:23 AM
Thanks John!
Appreciate those pictures John - I see exactly now where I will mount my sensors.
