Unread 07-17-17, 01:20 PM
B2C2 B2C2 is offline
DPE near KLVK
Hi
I am looking into getting my son his multi rating in my skymaster. I have an instructor, but the DPE I used based out of Hollister is no longer doing skymaster certs. Does anyone know of a DPE who can do this that is reasonably close to the bay area?
Ben
Unread 07-20-17, 09:28 AM
Multi rating
If he is issued his multi rating in the Skymaster he will be limited to centerline thrust aircraft only. If later he wants to fly conventional twins, the time in centerline thrust will not count. Suggest he do multi training in conventional twin. If he has conventional twin rating, Skymadter time applies as multi engine. It's a quirk in the regs.
Unread 07-22-17, 05:50 PM
Smile I Agree Totally
Don't make a big mistake, take the side by side ride and be fully multi engined
you will thank us some day
Unread 07-26-17, 04:15 PM
Yeah I had thought about that. Might end up having to go this route by default if we cant find the examiner.
Unread 03-15-23, 09:05 AM
Joes Joes is offline
DPE near KTRI for Instrument Rating CLT
Looking for a DPE for an Instrument check ride in a P337, any and all help would be greatly appreciated. I am located in the Bristol VA area (KTRI). Thanks, Joe
Unread 03-15-23, 11:40 AM
Check Virginia for ME/INST DPEs (DPE-CIRE-AMEL) on the FAA DPE locator site:
https://designee.faa.gov/#/designeeLocator
Results will include DPE contact information. Else, you can call the Richmond FSDO and they can assist in finding one.
Unread 03-16-23, 11:43 AM
Question
If you take an IFR checkride in a 337, are you limited to CLT, or can you fly IFR in any light twin?
Unread 03-16-23, 04:19 PM
TomM's Avatar
TomM TomM is offline
You will be limited to CLT if the plane does not have a published VMC. You can have the limitation removed by taking another check ride in a "regular" twin and do a few maneuvers. On the Airman Certification Standards there is a list for what needs to be done to remove the CLT rating. it is in Appendix 7 I believe.
The above assumes that you do not already have a multi-engine rating. If you already have one and want to get the instrument add on, I assume that it is about the same as you need to do a single engine approach as part of that work.
Unread 03-16-23, 04:51 PM
TomM's Avatar
Acs
Here is the ACS information. You do need to do the IFR in a regular twin, but here is the list of things you need to do to remove that limitation
Unread 03-17-23, 01:39 PM
Thanks for the good info Tom.
Unread 03-18-23, 05:23 AM
Thanks Tom, just what i needed.
