Old 03-20-17, 11:12 AM
kilr4d's Avatar
kilr4d kilr4d is offline
Rear crankcase vent outlet
As per the attached pics mine is broken and I can't find one anywhere; neither can Don Nieser. Cessna part# 1250101-6
Can someone post a couple pics of theirs? My mechanic might have to fabricate one.
John
ID:	1729   Click image for larger version
Name:	Crankcase vent outlet a.jpg
ID:	1730   Click image for larger version
Name:	Crankcase vent outlet b.jpg
_________
John K
1977 337G
CNC3
Old 03-21-17, 10:10 PM
John
It's just a tube nipple made of aluminum. Maybe for like 3/4 inch hose I would guess. If you have a good welder that you work with they should be able to work it out. The longer part is on the inside of the cowl with a tapered end to allow the breather tube to slide on. It also has a ridge all the way around that will keep the hose clamp from coming off. Try McMaster Carr they may have a nipple similar to what you need of aluminum and then clean up the cowling and weld in the new one. The original may have been pressed in.
I have a photo that I think is on the forum of a mod that someone did that took the breather out the bottom of the engine nacelle instead of all over the prop. You might search breather on the site
Old 03-21-17, 10:45 PM
http://www.337skymaster.com/messages...light=breather
Old 03-22-17, 10:37 AM
kilr4d's Avatar
John
Thanks Herb. There's still part of mine in the hose. I'm going to pull it out and see what it looks like.
-John
_________
John K
1977 337G
CNC3
