Old 07-30-14, 10:42 PM
Gord Tessier's Avatar
Rear engine oil drain outlet reposition.
Hi, has anyone moved the rear engine oil drain outlet away from the top of the engine and located it where it won't spray oil all over the rear prop?
Gord
C-FTES
Old 07-31-14, 06:56 PM
That would require a field approval for the mod
Where do you keep the oil level? I find anything more than 6 quarts ends up out that tube
Old 08-01-14, 02:05 PM
bking bking is offline
bking is on a distinguished road
What is a good rule of thumb for a minimum oil level?
Old 08-01-14, 05:02 PM
Start out with 8 quarts and the filter full, if applicable. Put some hours on the airplane, say about 25 max, checking the oil closely to determine at what point the level stays stable. Now the caveat, obviously if the level goes below 4 quarts you better add some oil and figure out a solution to your oil use, like new engine . But at some point the oil level should stabilize, 6 to 7 quart level with the filter full, and you will find that this is a good level to minimize the mess on the belly and the butt.
Also, is your dip stick level reading correctly? When the oil is drained for oil change and the new filter is installed, as you add new oil check the level indicated on the dip stick. You may find that when you think you have 6 quarts you really have 7. You may need to re-mark the dip stick accordingly or mentally make a correction for that engine. I have seen this exact scenario, the pilot wanted to maintain 7 quart level but really had 8 quarts and grease all over the belly and butt. This is just my opinion of how I operate and many may not agree. Always consult the POH or Continental Engine Manual for the printed information. I don't think Continental indicates the minimum level but Lycoming says to never go below 2.5 quarts on a 8 quart system in the 360 series engine.
Old 08-01-14, 05:08 PM
Thanks for the info and I will verify the markings on both dip sticks.
Old 08-03-14, 10:32 PM
I saw this Saturday, I think this is what you are referring to
Name:	N5383S A breather sml.jpg
Old 08-15-14, 05:05 PM
Thanks Herb, I will show it to my mechanic.
Gord
C-FTES
Unread 08-18-14, 01:14 AM
GMPoland GMPoland is offline
GMPoland is on a distinguished road
Oil vent
I ran mine to nearly same location to accommodate an oil/air separator.
GM Poland
