  #31
Unread 08-30-12, 01:06 PM
Originally Posted by James Bennon View Post
Herb, kind of off subject but do you know of the feasibility of converting the rear seats of a 73 P model from fixed position to sliders?
JB
Sorry James I do not. It sounds like it would require a field approval. It may not be impossible because the P model had the slider seat later in the manufacturing run. Not sure if the H model was the first or if there were G models with the slider?
Good Luck
Unread 08-31-12, 03:27 PM
JeffAxel JeffAxel is offline
I think the slider seat started in the '75 P models. My '77 had it. The fuel tanks also changed in the '75 models with long range fuel going to 148 gallons, no tank switching except to cross feed.
Unread 08-31-12, 04:37 PM
Thanks Jeff, I need to find someone that has installed later model rear seats in a 1973 P model to establish whether it is possible.
JB
Unread 09-01-12, 07:31 AM
JimC's Avatar
JimC JimC is offline
I would suggest that you read these posts from Dennis Hamblin of Flint Fuel Tanks. There is a post that describes the differences in the wings of P model Skymasters.
http://www.337skymaster.com/messages...earchid=585613
Found it, for those interested in reading the spar construction info..
http://www.337skymaster.com/messages...2&postcount=31
