Unread 10-24-11, 10:02 PM
Guy Paris's Avatar
Aft cowl breather outlet
Hi All,
Any ideas as to where can I get the small tubing that is in the upper rear cowl that the rear engine breather piping exhausts thru? The aircraft is a 1977 337 G. The part #1250101-6. Has anyone dealt with this in another way?
Thanks, Guy, the old 72 driver....
Unread 10-25-11, 07:42 AM
Gord Tessier's Avatar
Hi, isn't it just stock hose. I know there is a metal end that comes out the back through a large grommet.
Gord
C-FTES
Unread 10-25-11, 10:27 AM
Guy Paris's Avatar
I believe it's a small piece of metal tubing that is flared on the end that protrudes thru the aft cowl just above the prop hub. Hose would connect to the end that's inside the cowl.
Thanks, Guy....
Unread 10-25-11, 07:11 PM
Search shows one here
http://www.texasairsalvage.com/Aircr...php?editid1=19
