Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 09-28-11, 12:48 PM
Location of Temperature Sensor
I have a 1965 Cessna 337 Skymaster. I am trying to install F&M oil filter conversions instead of the oil screens, however, my skymaster seems to have the oil temperature sensors installed in the back of the oil screens. Can anyone tell me if there is an alternate location for these temperature sensors, and possibly include pictures for reference? I have attached a picture of what I currently have. In order to install the oil filter conversion, these have to be relocated as the STC does not include provisions for tapping the end of the oil filter adaptor body to accept these sensors. Click image for larger version
Name:	Oil Screen - Temp Bulb.JPG
Old 09-28-11, 06:20 PM
Originally Posted by mhudsonbsme View Post
I have a 1965 Cessna 337 Skymaster. I am trying to install F&M oil filter conversions instead of the oil screens, however, my skymaster seems to have the oil temperature sensors installed in the back of the oil screens. Can anyone tell me if there is an alternate location for these temperature sensors, and possibly include pictures for reference? I have attached a picture of what I currently have. In order to install the oil filter conversion, these have to be relocated as the STC does not include provisions for tapping the end of the oil filter adaptor body to accept these sensors. Attachment 1304
Most have the temp sensor at the base of the oil cooler. if you don't have a plug there you may have to change the oil cooler adapter plate.
Kim
Old 09-28-11, 06:34 PM
We installed the F&M adapters couple of years ago. Great system, they have been fantastic. As Kim indicated my sensor was in the oil cooler. I just installed the JPI and it has oil temp and used the port right behind the prop on the engine case. There is an plug right on top that can be removed with a hex key allen wrench. I will see if I have some photos.
Old 09-28-11, 09:15 PM
Here is a photo of the front engine port and the rear engine port for oil sensor.
ID:	1305   Click image for larger version
Old 09-28-11, 10:29 PM
Thanks for the information! What JPI system did you install? Did you keep the factory oil temp gauge as well? Any chance you might also have a picture of the factory probe location on the oil coolers? I really appreciate all of your help!
Old 09-29-11, 09:17 AM
I will check my photos and see if there is a photo that might show the cooler location.
I installed the EDM760, old school but money was a factor. I would have liked to gone to the full digital display but too involved. Everything factory stays. I did put in the fuel flow option which I really like.
Old 10-20-11, 07:28 PM
Here is the Oil Temp Sensor on the rear oil cooler. In the middle with the boot over the sensor for the wire connection.
Name:	Oil Temp Sensor Rear.jpg
Old 10-24-11, 08:09 PM
wonderful! I appreciate the help. I am going to relocate my sensors next weekend!
You don't happen to have the part numbers for the connectors, do you? I will probably need a different type. Looks like a tight fit. Or can you use a 45 elbow to redirect the sensor for easier access?
Thanks!
Mike
Old 01-18-12, 09:55 PM
Part number for Oil Temp Sensor
Do you happen to know the part number for the factory oil temp sensor? My sensor has 2 wires going to it on the 1965, however later models seem to only have one sensor wire. Does anyone know if the later oil temp sensor will work with the first year skymasters? Thanks, Mike
Old 01-19-12, 09:01 AM
I would contact Don, he should know
Don Nieser
Commodore Aerospace Corp.
6221 Commodore Lane
Oklahoma City, OK 73162
405-722-4079 cell = 405-503-4686
