Front Prop Hub 1965 337
Hi folks, looking for serviceable hub for front prop 1965 337, sn 0025.
Thanks; Brian 281-468-7755 Last edited by brian : 01-28-10 at 08:19 PM. |
Who have you talked to? Did you call Don Nieser at Commodore Aero?
Front Prop Hub
This was a learning thing for me. Noticed some red oil dripping from the prop. Local mechanic said that sometimes happens after sitting and they sometimes re-seal after a longer flight. But it was past TBO calendar and hourwise so we sent the prop in as part of the annual inspection. So, I sort of figured this could happen, have often heard of corroded blades, or hub during these things. Apparently my blades are okay, but hub has too much corrosion. A re-seal job for the rear prop (5 years since new) has crossed my mind as a result of this. If I hit the lottery this week I would go ahead and put new 3 blade composites on front and rear. ![]() Brian |
Expensive toys we have............go for the MT's, you'll love em.
Well, just to give you something else to think about, when I decided to have my props checked I sent front and rear in for inspection and the shop condemned all 4 blades and one hub could not be re-built. That's what started the shopping spree in Germany for the MT's. Now I have 6 years on them and it's time for OH all the MT's. I will fly the plane to Florida in March for the overhaul at MT's USA service center and then fly home on Delta. When I return in April to pick up the plane it will go to Sun N' Fun for SPRING BREAK with all it's cousins. Get yours ready and come join us. Good Luck on the hub
Front Prop Hob
I ended up locating a new hub. It was around $4500 as I recall.
Brian |
hi ,i got a perfect hob for your 337,,,the cost is 3700,im in bolivia ,,
my fone number is 591 708 32211,,,i need 2 blades for my front engine prop do you know whom to call or contact ,,,thanks akram |
hi brian
do you still got the condemned blades,and are they for the front engine,,if so please give me an estimate if they never had accident,,,thnx akram |
2 Blade Props for sale
| Thread Tools | |
