Unread 04-05-10, 12:45 PM
N5ZX's Avatar
N5ZX N5ZX is offline
N5ZX is on a distinguished road
SkyMaster Wing Mods
Just a quick check to see how many of us have wing mods.
I have :
20gal Extended Tip-Tanks.
Rocket Winglets
Stall Fence
Flap-Gap seals
What do yall have?
Cole
Unread 04-05-10, 01:54 PM
Roger's Avatar
Roger Roger is offline
None of the above.
MIcro VG's and standard (long range) 150 gals.
Unread 04-05-10, 02:18 PM
Flint Tip Tanks
http://www.airliners.net/photo/Cessn...zed/1673232/L/
Unread 04-05-10, 10:20 PM
Ouch!
It is unusual to see the mains fail and the nose gear hold up.
Unread 04-05-10, 10:42 PM
Dad's first Skymaster, 1967, on landing both mains failed. The down locks did not secure for some reason, don't remember the details.
Unread 04-05-10, 11:08 PM
No mods here. Plane is as was in 1973 when it left the Cessna factory.
Ed
Unread 04-06-10, 11:02 PM
I have an OWL STOL kit.
The kit includes a leading edge and wingtips.
I'm currently investigating replacing it with a Horton STOL kit, but they are unsure if the Horton STOL will cover up the rivit holes created when the OWL STOL kit was installed. I'm still waiting for the answer.
Karl
Unread 04-10-10, 01:12 AM
Just an update incase anyone might have a similar situation. A Horton Kit will not fit on the same foot print as an OWL STOL kit. I would have to get a new leading edge or wing skin replaced and that's not worth it in my opinion.
Karl
Unread 04-10-10, 09:36 PM
sloutitt sloutitt is offline
sloutitt is on a distinguished road
AE tanks and had AE tips
We have 20 gal tanks, (aviation Ent) and had winglets (AE) but after reading some of Coles posts and reviewing the SB we removed the winglets. Just did not want the stacked mods. Owen Bell supplied the stock style replacment tips and they fit perfect. We conducted the SB and found no bending, smoking rivits or distortions.
Sandy Loutitt
PS cole I did send you a Private message though I do not know if you recieved it.
Unread 04-23-10, 10:59 PM
Horton Stol Wing Kit and Aviation Enterprises Lightning Winglets. Is that considered a stacked mod? Guess so. When installing the winglets I first tried to use a sheet metal screw between the original screws but did not like the results. I installed rivnuts on all fasteners and it just is much better mounting process.
ID:	1107   Click image for larger version
ID:	1108   Click image for larger version
ID:	1109   Click image for larger version
ID:	1110   Click image for larger version
Unread 04-24-10, 09:59 AM
tropical tropical is offline
In my opinion the "winglets" give the airplane a goofy look. And there is no aerodynamic advantage to have them.
Unread 04-24-10, 10:45 PM
Alfonso Alfonso is offline
Alfonso is an unknown quantity at this point
Original C336 And Fuel Questions
It has the original 46 gallons main fuel tanks and the 20 gallons auxiliary, for a total of 128 gallons, no reserve. I was planning to install the AE 20 gallons wing-tip tanks, but it is on hold until the NTSB clears those tanks from the C337 crash in NJ. I am considering instead internal aluminum tanks. Any suggestions?
FUEL QUESTION: Does any one has any experience in not getting fuel to the engines when low in fuel (7 gallons remaining on each main tank) and on level flight with flaps extended (low nose)? I understand some main tanks have front and rear tank-pipes to drain the fuel into the fuel selector, and others only have one pipe in the rear of the tank. Any suggestions or explanations are appreciated. Thanks.
Are there any further news from the NTSB or FAA on the C337 crash in NJ?
Alfonso.
Unread 04-25-10, 08:14 AM
Ace of the Atmosphere
The main tanks all have fwd and aft outlets on all of the 337's. Both feed a small header tank in the lower boom, aft of the lift strut attach point. That is where the sump drain valve is located.
The aux tanks have a 18 gal capacity, not 20 gal, and all is usable.
If you are having problems with fuel feed, check your vents to assure that they are free and clear.
Unread 04-25-10, 09:00 AM
Original C336 And Fuel Questions - conitinued...
After 3 hours of flight, I used the auxiliary tanks for 30 minutes, which I estimated it used 5 gallons per auxiliary and transferred about 7 gallons surplus fuel to each of the main tanks, leaving about 7 gallons on each auxiliary tank. Is there any procedure or requirement that states that when the auxiliary tanks are used, they have to be used all the way until they are emptied? I landed with a total of 26 gallons of fuel, but I do not like hearing the engine sputtering due to lack of fuel even though there was sufficient. The C336 generally flies with the nose always high about 2 to 3 degrees up, compared with the C337. So when the flaps are extended the wing flies flat relative to the earth, and the fuel in the main tanks spreads to the whole flat tank-wing rather than depositing in the rear of the tank when the nose is up, and where the fuel pick-up pipe is located to send the fuel to the fuel control valve. I remember reading about several years ago of a Skymaster, I do not remember if it was a C336 or a C337, that crashed short of the airport due to fuel starvation even though they apparently have plenty of fuel. Any comments, suggestions, articles, etc would be much appreciated. Thanks.
Unread 04-25-10, 09:13 AM
Thumbs up Thank You Skymstr02
You are correct, the auxiliary tan has a capacity of 18 gallons, all usable. I was thinking in the 20 gallos tip tank. Thanks again. Any other ideas are welcome. Alfonso.
