Unread 11-26-25, 06:12 PM
Burt Burt is offline
Dukes Fuel Pump
Does anyone know where I can get parts for my Dukes aux fuel pumps? They are very easy to overhaul if parts could be found.
Unread 11-27-25, 09:39 AM
Frank Benvin's Avatar
I bought complete units from aircraft accessories You can check if they sell parts
https://aircraftaccessoriesofok.com/
Frank
1967 337B
Unread 11-27-25, 06:45 PM
Thanks, I will check with them.
Unread 11-29-25, 10:55 PM
Joes Joes is offline
PMAD Weldon 18000 Fuel Pumps
Unread 11-30-25, 11:32 AM
This pump is only certified for the E model and newer -
Good for these models - 337E, 337F, T337E, T337F, F337E, F337F, FT337E, FT337F, 337F, T337G, P337H, FT337GP, FP337H, 337G, 337H, F337G, F337H, T337H
I have a 337b and replace it with the dukes as it was certified for my 337
Frank
1967 337B
Unread 12-09-25, 10:23 AM
Dukes Fuel Pump
After an exhaustive on-line search and many phone calls I gave up trying to find the part that I needed and ordered a new pump so I will be back in the air in a few days. I am keeping my old pump since it was functioning perfectly except for a very slow leak along the shaft due to the "bearing and seal assembly" being worn. It still has many serviceable parts including the motor.
I discovered that McFarlane lists most of the parts for many aux pumps but not the part that I needed. McFarlane owns CJ Aviation which is the only authorized repair/overhaul facility for Dukes pumps that I could find in addition to the original manufacturer but CJ will not release the part that I needed. And of course Aero Fluid Products (formerly Dukes Aerospace) does not sell any parts but they will repair/overhaul my old pump. So I may send them my leaking pump to fix and keep it for a spare.
Burt
Unread 12-09-25, 02:13 PM
Thank you for sharing the information. Good Luck..., Ed
Unread 04-26-26, 06:05 AM
Don’t bother overhauling a Duke. Just get a new pump CJ aviation fuel pump.
