Unread 07-25-23, 04:34 AM
cessnadriver's Avatar
Thumbs down removing front alternator
Hello ALL.
Need some advice on removing my front alternator. Having a problem with the front alternator not charging, did the diagnostics. I read in the MX manual and it does say to remove it from the left side of the aircraft. But has anyone remove one before. NEED HELP!!
Thanks in advance
Regards, BILLS
Owner, Pilot, and A&P
Unread 07-26-23, 08:53 AM
Joes Joes is offline
I'm told the essentials are:
1. 1/4 in set of crow feet wrenches
2. 1/4 in wobble extensions
3. 1/4 in to 1/8 in strip of black tape wrapped clockwise on nuts so when the
tape is pulled the nut rotates onto the stud. Use screwdriver or finger with
grease to hold nut in place. (my favorite for any tough nut location,
especially the vacuum pumps).
Is the anymore tips or techniques for tough location anyone has used. Please elaborate if so, thanks Joe
Unread 07-26-23, 03:37 PM
Save the aggravation.
Find 20* btc; remove left magneto. Remove clamp holding breather tube; rotate out of way. Remove / replace alt.
If no one has messed with prop or magneto. Reinstall,
You DO keep spare mag gaskets; right???
Unread 07-26-23, 05:12 PM
Frank Benvin's Avatar
FYI
Ordered a alternator seal using the part # from the Continental IO360 Parts Manual thru Aircraft Spruce Part # 352068
This has happened twice now
Received a SKF 9613
Alternator had a SKF 8648 in it
Just looked at aircraft spruce it it shows this part # is for a Generator Attaching Parts for Continental C85, C90 & 0-200
If you are ordering parts you might want to double check what you need and what you will get
1967 337B
Unread 07-26-23, 07:18 PM
Ok.
I saw your Aircraft Spruce remark. “ wasn’t AS fault”.
Not sure where we’re going with this….( always a good idea to know what you are ordering)
The alternator gasket is 649984— $4.95
The gasket is used to mate alternator to engine.
Not sure where your seal goes. Have you checked with the alternator manufacturer / repair facility.?
Unread 07-26-23, 07:56 PM
I looked in the Cessna parts catologue - 1965 - thu 1969 337
Mine is 1967 337b
We took all assesories off engines and replaced all seals o-rings and gaskets
Ordered parts from aircraft spruce
Alternatior parts replaced
#1 - part # 352066 gasket - crosses over to 649984
#5 - part # AN123864 o -ring - crosses over to AS3570-111
#6 - part # 352068 -seal - no cross over this was a SKF9613
When we pulled alternator it had a SKF8648 in it
I have attached break down from parts catolouge
1967 337B
