Thread Tools Rating: Thread Rating: 10 votes, 1.00 average. Display Modes
Unread 01-27-22, 02:34 PM
DrZGard's Avatar
DrZGard DrZGard is offline
DrZGard is on a distinguished road
Performance Tables for 74 P337 vs Riley Super SkyRocket
I have taken the book figures to make a couple of Excel spreadsheets for performance tables comparing a 1974 T337G to Riley's Super SkyRocket conversion with the TSIO520's. The book figures only show MPH and LBs of fuel burned and total range exhausting fuel (which is a misleading figure). These tables add Knots, gallons per hour and range with 45 minute and 1 hour reserves. The 74 SkyMaster carried 123 gallons/738 lbs while the Super SkyRocket carries 148 usable/888 lbs.
I turned the excel files into pdf files since they didn't want to upload.
Unread 01-29-22, 01:13 PM
Curious, why the choice of 2200 RPM?
Unread 01-29-22, 02:13 PM
DrZGard's Avatar
2200 rpm is the max continuous rpm after initial takeoff and climb as well as cruise in the Riley Super SkyRocket. I know... interesting.
Unread 01-29-22, 02:24 PM
Learn something new everyday!
Unread 01-31-22, 03:25 PM
Dr.Dan's Avatar
Dr.Dan Dr.Dan is offline
Interesting, thanks. The P337 values are very similar to what I've experienced with my '73 P337 so far. The Rocket seems to have a significantly increased fuel burn for a modest increase in speed. I guess one other factor is it gets up to altitude quicker.
DD
1973 T337G
Unread 01-31-22, 03:40 PM
DrZGard's Avatar
DD
The STC only allows full power, which is 300 hp, not 310 like the same engine in 340. 38"@2,600rpm for 2 minutes. Then 34"@2200rpm for max continuous (which ironically is 225 hp). The other interesting factor I discovered is the AD for the engine back in 2009 instructing to NOT operate at rpm's below 2,300 for cruise. If I can get a chance to talk to a Super SkyRocket pilot I can ask if they use something other than the 2,200 which the Riley POH calls for.
