Unread 02-22-21, 03:54 PM
JohnT JohnT is offline
JohnT is on a distinguished road
WANTED- Door seals for a pressurized T337G
Hello, I'm new to the forum, thanks Herb! I have a '72 P337G and am in desperate need of door seals. Just over the last two years the current ones have lost their ability to seal and pressurize the cabin. Cessna no longer carries these seals: 1511446-1 and 1511418-1. Does anybody have any of these or know a source for the bulk material or suitable replacement? I'v searched many parts suppliers and salvage yards to no avail. Has anyone had any luck getting a field STC for a Bob Fields inflatable door seal on a 337? Any help would be GREATLY appreciated!
Unread 02-24-21, 05:44 PM
Aeroval shows then at $3,130 each: https://aeroval.com/ref/936185/1511446-1/
Not sure if they have them in stock or not.
Let us know what you find out. I would think you could use a similar seal from another pressurized aircraft.
Unread 02-24-21, 08:25 PM
Thanks!
Thank you! I will certainly report back whatever I find out. I knew that they would be expensive if they could be found...
Thanks again!
Regards,
John
Unread 03-01-21, 10:13 AM
Aeroval responded with, "no stock, no lead, no quote". I appreciate you trying to help. The search continues!
Unread 09-22-21, 04:05 PM
So, did you ever find a door seal.
Unread 09-22-21, 05:00 PM
mikezen mikezen is offline
mikezen is on a distinguished road
Door Seals for P337
Good evening
@mshac : I only could find this thread !
But no solution for new door seals for P337...
Unread 09-22-21, 05:02 PM
Because there is no solution I'm aware of, other than using seals from another pressurized aircraft. Check 400 series seals, my guess they will work. Let us know what you find.
