Unread 02-19-20, 09:46 PM
Pitot heater element
I may have some of the pitot heater elements in the near future for those that may be interested
Dan
67S
Unread 02-20-20, 04:29 PM
kbecker kbecker is offline
I’m interested
Unread 02-22-20, 07:33 AM
I'd like a spare.
Unread 04-24-20, 04:46 PM
Dan, do you have any of those elements? I'm in need of one.
Unread 04-29-20, 07:27 PM
Don’t have any yet, I have a vendor, specs, drawings, no parts yet.
Dan
Unread 05-23-20, 10:01 PM
MD83driver's Avatar
Dan, I would also be interested in buying one!
Unread 05-24-20, 02:56 AM
Dan. Count me as interested!
Unread 05-24-20, 12:11 PM
YankeeClipper's Avatar
+1 .
Unread 11-23-20, 07:23 PM
First 5 units scheduled for delivery Dec 18. Units will be universal for P models and unpressurized models. The two .070 holes for the pitot head are in different positions between the pressurized and unpressurized models.
Dan
Unread 11-24-20, 10:10 AM
Dan
Confusing statement - "Units will be universal for P models and unpressurized models"
but then you say - "The two .070 holes for the pitot head are in different positions between the pressurized and unpressurized models."
So which is it? Are they universal, or will you be producing two versions?
Unread 11-24-20, 10:53 AM
What I am trying to say is the heater is universal for both versions. The heater will have two sets of holes (.070) one set is used for P models, and the other set used for un-pressurized.
The holes for a pressurized aircraft are .050 from the center line of the part, .600 inches apart.
The un-pressurized aircraft has the top hole .100 from the center line (yes the front hole will look like a Mae West), and the lower hole is .150 from the center line, these holes are also .600 apart.
These dimensions are from the SE1230-7 template as described in ME75-6.
Installation will be using two #50 drill bits (supplied) that you will put in your existing holes, peel off the release paper from the back of the heater and slide down over the the two #50 bits which will align the heater to the aluminum pitot block. One wire from the heater will be RTV'd down the channel on the pitot block to the Thermo Disc temp controller, the other wire will connect to the aircraft blue power wire. Once this is completed you will leave the #50 bits in place, place RTV on the heater unit and install in the strut fairing. When the unit is installed in the strut fairing with the two screws, then the #50 bits will be removed. These instructions are what is described in the maintenance manual, and ME75-6 Replacement Procedure, and Figure 1, Pitot Head Replacement 337, F337, T337G, FT337G
So the long and the short of it, instead of making two different parts, all four of the .070 holes are incorporated into one part making it a universal fit when installed, RTV will seal the extra set of holes.
Dan
Unread 11-24-20, 06:19 PM
Thank you for the clarification!
Unread 11-25-20, 09:47 AM
Can you post a picture when you have one? A photo always helps.
Unread 05-07-22, 01:37 PM
PH502 24 volt heated pitot (used ebay)
I know I had mine replaced years ago, and it was under $300 new.
My my, how time flies....
Just curious: Would these work on older 337's, albeit used?
Unread 05-07-22, 03:50 PM
The flexible heater is universal for pressurized and no pressurized aircraft. Two different sets of holes.
Dan
