Unread 11-14-17, 08:39 AM
tomcomet's Avatar
tomcomet tomcomet is offline
tomcomet is on a distinguished road
Brief Electrical System Malfunction
I had a strange situation on a recent cross country flight. First I noticed the radios “getting stcatchy” and they all lighting flickered a bunch and soon after that all electrical died entirely. I was a little concerned so began an orbit before I progressed any further into controlled airspace.
I checked all breakers - all good. Next I tried AV master Off then ON - nothing. After that I did AV master, BATT and ALT masters all OFF then ON and things slowly came back up. Within a minute or so all was working again and I continued gingerly on my way. It might be my imagination but the ONE instrument that didn’t seem to loose power entirely was my DME. Weird.
John K figures I maybe tripped the alternators and didn’t notice... This could be as I recently mounted my full sized iPad on the yoke and it sort of covers those lights. They are so bright that I definitely notice them when they occasionally flash on the ground but perhaps my position and/or focus is different in flight and I missed them. I hope this is true cause that will be much cheaper than other options...
Thoughts..?
TC
1977 Reims Built F337G
CYFD
Unread 11-14-17, 09:26 AM
I cannot say for any certainty what occurred however the fact that the electrical system returned to normal after you turned the master switch off and then back on implies that you reset the over-voltage sensor. Read the POH on the over-voltage sensor operation.
I am currently struggling with this for the 3rd time in my ownership experience since 2002.
Simply put, the over-voltage sensor is designed to shut the alternators off if the sensor senses more than I think it is 32 or 32.5 volts across the electrical system. It is in place to protect your avionics from getting fried by too high of a voltage. Normal voltage should be about 28.5 volts across the system if all is set up and working properly.
If the over-voltage sensor trips, on the panel you should see the annunciator lights illuminated indicated the alternators are off and the red volts high light should also be illuminated indicating an over-voltage event occurred. The procedure to reset the over-voltage sensor included turning the master switch off for a few seconds to reset the sensor. The procedure is all spelled out in the POH.
In my POH for my 1973 G model, the manual states "if the condition was temporary, resetting the over-voltage sensor will return the electrical system to normal operation."
This implies to me that for some reason (please note I do not understand electricity) Cessna thought when they built the airplane that a temporary condition could exist that could cause this at some random time.
My personal experience with these conditions has been a malfunction is occurring in the system. They have not been temporary at all. The answer will come to you if this event reoccurs frequently as you fly along. In the mean time, I would fly along cautiously avoiding IFR conditions until you fully understand what is going on here. You wouldn't want to be in the clouds without electricity.
I have written posts on my experiences with over-voltage conditions on this forum that you can read. I am currently working on this again for the 3rd time on my airplane and do not have the answer yet for this latest round.
Keep in mind, that I have no clue what happened in your case. I simply am basing what I said on the behavior you described with the limited information in your post. If this happens again, see if the red "volts high" light is illuminated before turning the master switch off. This would verify if it was in fact an over-voltage event. Actually, let me rephrase..., it would indicate that the over-voltage sensor tripped. Maybe an over-voltage event occurred or maybe the sensor is faulty, tripping when it should not have.
Electrical problems in my opinion are the worst maintenance events to have. In my experience, nothing is more difficult to resolve.
Good Luck,
Ed
Unread 11-14-17, 12:11 PM
A former member Pete Somers, God rest his soul, was a great contributor to this forum concerning electrical glitches
Tom, you may find some very interesting dialog in Pete's posts. I did a search on Over Voltage and there is lots of goods available on this forum. These events are never new to this forum and because we have about 15 years of posts on this forum there is probably an answer somewhere in the old posts. I didn't have time to drill down today on this issue so when you have time here is some info to research and learn
http://www.337skymaster.com/messages...archid=1327591
Unread 11-14-17, 12:13 PM
tomcomet's Avatar
Thanks for this Herb. I will do some digging as I hope to avoid this predicament in the future.
TC
TC
CYFD
Unread 11-22-17, 02:49 PM
B2C2 B2C2 is offline
It has been pointed out in several posts but bears repeating that the system voltage will get unstable if you have more than the nominal resistance in the field circuit to the alternators. I have also several times had this issue. The first time all crimps were replaced behind the panel in the circuit feeding the field circuit for the alternators. The second time it was fixed by replacing the regulator selector switch. In my 1969 T337D this switch feeds either Reg 1 or Reg 2. Both regulators were showing jumpy voltages. Occasionally lighting the red overvoltage indicator. Replacing the regulator switch caused the voltage to be rock solid. After this was done I disassembled the switch and sure enough the terminals inside were badly worn. I would guess you had an overvoltage condition causing the alternators to go offline. then on recycling everything you got the circuit back. If you have a voltage indicator in your plane look at this. If its jumpy you probably have a field circuit issue.
Unread 11-22-17, 06:07 PM
1973 G models and on, DO NOT have the regulator switch. Just so you are not confused the front / rear regulators are automatic in the G and H model Skymasters system. The older system is different and uses a pilot selectable regulator switch.
