Old 09-26-17, 01:32 PM
rmorris rmorris is offline
rear engine after rain storm
My plane is almost always outside in the weather. One thing I noticed as a pattern - after a really heavy rain storm, the rear engine is hard to start.
I thought it might be the engine...but I have a practically new engine now, and it still does the same thing....starts super easy most of the time, but if I go to the plane after a heavy rain event the rear engine takes literally minutes of cranking to get going.
this happen to anyone else?
Old 09-26-17, 02:53 PM
kilr4d's Avatar
kilr4d kilr4d is offline
Mags getting wet somehow?
_________
John K
1977 337G
CNC3
Old 09-26-17, 03:43 PM
JimC's Avatar
JimC JimC is offline
Minutes of cranking? How are your starters holding up?
I'd lean towards wet mags as well.
Old 09-26-17, 03:44 PM
JimC's Avatar
And it's possible that only one mag is getting wet, but the other is already weak and you just haven't noticed.
Old 09-26-17, 07:29 PM
Obviously could be a bad mag, but doubt it
this was a symptom of the 'old' engine...but now I have an engine with 40ish hours on it doing the same thing, and the mags were definitely overhauled.
I was thinking that maybe the air filter was getting a bunch of water in it from the top scoop, then sucking it into engine
basically engine starts immed, but then dies out after about 5 seconds or so...and then takes many minutes of cranking (with small rest period for starter).
yes, tough on starter, which is why I was wondering if others are seeing anything similar.
Old 09-26-17, 07:34 PM
kilr4d's Avatar
Originally Posted by rmorris View Post
basically engine starts immed, but then dies out after about 5 seconds or so....
That sounds like loss of fuel?
Do you have fuel flow gauges? Have you tried leaving the boost pump on low?
Does it spit unburned fuel out the cylinder drains while you're cranking?
_________
John K
1977 337G
CNC3
