Unread 02-06-15, 06:30 AM
Diego Prescenzo Diego Prescenzo is offline
Diego Prescenzo is on a distinguished road
ELT antenna positioning
Hello
FT337GP, I need to find out if the original ELT antenna doubler is now installed.
A/C S/N FP3370007. ELT bracket is correctly positioned in the right side of the airplane, rear cockpit ceiling, according to IPC. I can't identify the correct antenna doubler as per Avionics Manual D4509 Fig.2-6 sheet 6 of 6 (P/N 1260474-2). Can someone confirm if the original ELT antenna positioning on the 337 does not vary with S/Ns (so it remains on the left rear side) even if the Original Sharc 7 ELT bracket is on the right side of the rear cockpit ceiling?
Thanks for cooperation
Regards
Unread 02-06-15, 10:48 PM
Hello Diego
The attached PDF file is from the Service Manual for the USA manufactured G & H model pressurized Skymaster. Take a look and see if this helps your trouble. Let me know if this is a duplicate of your Service Manual. We will try something else, Chow
Unread 02-07-15, 04:39 AM
Thank you for the Scan of the manual, but unfortunately it's pratically the same of mine and it does not help to see the accurate antenna positioning. For anyone who has the original ELT antella location, a photo of that part of the airplane will be great!
Regards
Unread 02-11-15, 03:46 AM
ELT antenna position photo
can anyone be so kind to made a photo on their actual ELT antenna position? I need to know due to new installation certification issue in EASA environment, please HELP!
Regards
Unread 02-11-15, 09:58 PM
Diego
I would suggest you might try to contact Don Nieser
nieser.02.337parts@juno.com
405-722-4079
