Unread 11-29-12, 12:46 PM
Wildman6 Wildman6 is offline
Wildman6 is on a distinguished road
Dpe
Is there anyone out there in the State of Oregon that is a DPE, that can do endorsements for C-337's??
I need to get a the "Center-Line- Thrust" endorsement and here in Central Oregon it's like pulling teeth... I have talked to a CFI that's Multi engine, he has NO 337 time.. He says he needs 5 hours to get the certification.. But he will need 2 hours with me, getting him familiar with the aircraft, then he'll have to do the 5 hours "Solo"
This sounds like Bull to me.. I own this aircraft and was ready to have the check ride when my instructor was hired to fly for the Majors. I'm stuck with a 337 that I can fly solo, or have a MEI that has at least 5 hours in 337's tag a long with family on trips.. might as well sell it and get a 210 or 172..
So my situation is, is there ANY DPE for C-337's beside the one in Bellingham,
Washington State.
Anyone out there that can HELP?.
Wildman6
Unread 11-29-12, 09:32 PM
Why not just get a MEL rating in a standard twin? Are you referring to an insurance requirement?
Unread 11-29-12, 10:19 PM
hharney
I was using my G.I. Bill to get MEL.. I went through 4 CFI's, they hit the 750-1000 hour mark and bail..
I was flying the PA-44 Seminole. But now $350 + an hour Vs. $45 an hour in my aircraft. Yes on insurance issue,I can't have another person fly the aircraft (PIC) unless he or she has 25 hours in 337's and I have them on the policy.
Do you happen to know anyone?.
Wildman6
Unread 11-30-12, 12:24 AM
I hate to open a bee's nest, and I realize this is not on topic, but an hour of YOUR 337 doesn't cost $45. Even when you ignore items unaffected by flight hours (like hangar/tie-down and insurance) the airplane cost is probably in the $200 - 250 range when you consider fuel, oil changes, engine and prop reserves, and a kitty to cover the wear and tear of flights (tires, brakes, etc.).
Unread 11-30-12, 01:47 AM
Dpe
Ernie,
I was only doing the CFI hour. Beside's I'm doing instrument flight now, rather use My plane instead of a 172.. Like using V.A. money in my aircraft instead of someone else's.
Wildman6
Unread 12-01-12, 11:28 PM
JeffAxel JeffAxel is offline
you might try Larry Schmidlin at 503-939-8264. He is a CFI out of HIO. Not sure if he can give you the exam, but he knows Skymasters. Might know someone who can if he can't. That said, there is a lot to be said for getting a multi rating in a conventional twin. That is how I did it, anyway FWIW.
Unread 12-02-12, 02:42 AM
Dpe
Thank You Jeff,
I'll call him on Monday. I have been working on the Mulit rating, but like I said here in central Or. as soon as these CFI's hit the 750 - 1000 hour mark they bail for better jobs.
After 10 - 15 hours with one, he bails then another CFI fill's in. The flight training is now 5 hours more or less to show what I was taugh then, he starts his way of training then he leaves, so on and so forth. Like a dog running around a tree after his tail.
I plan on doing the muilt training again in the spring term, maybe these CFI's will stick around long enough to get the rating.
Again Thanks
Wildman6
