Unread 01-03-07, 10:43 PM
birddog birddog is offline
back up oxygen
I have a Riley Skyrocket with oxygen generators. Do all P337's use OG's or is this unique to the Riley Skyrocket?
How to make vaporizer
Unread 01-04-07, 05:28 AM
The generators are stock from Cessna. They are an emergency oxygen source, not a sole source, ie, gaseous, that you would find on a non pressurized airplane.
They are only designed to keep you alive until you can decend to a breathable altitude, and they do get very hot when activated.
Unread 01-04-07, 11:54 AM
Thanks for the input. Is/was this a common system in high wing cessna's (210's,337's,etc). Is it a weight advantage over the bottle system? I was thinking of doing some research on converting but maybe thats not possable or practicle. Thanks.
Mightyboy
