Old 03-03-23, 02:11 PM
Burt Burt is offline
Brake line hydraulic swivel
Anyone have information regarding repair or replacement of the main gear brake line hydraulic swivel fitting?
Old 03-03-23, 03:29 PM
There are posts here showing how to rebuild it yourself for 75 cents. Shows how it comes apart, etc.
here's one, there are others: http://www.337skymaster.com/messages...ghlight=swivel
Use the search function.
Old 03-13-23, 06:22 PM
Rebuilt my left one last year, put between two pieces of aluminum in vice, remove internal circlip, remove roll pins, take apart, replace oring, reassemble.
Dan
Old 04-14-23, 01:49 PM
GAdams GAdams is offline
My brake line swivel has seen better days. Someone previously beat the crap out of it and it is no longer serviceable or repairable. I found a replacement part which is a Phoenix C6-4-6. Cost about $10 plus shipping. Using FAR 43.13 to install. Far better replacement part than the original. Early serial number Skymasters had no brake swivels. I don't know the history on the swivel but I assume it was an improvement done by Service Bulletin in the early days. Then incorporated into later production airplane.
Old 04-14-23, 11:53 PM
Awesome news brother!
Old 04-15-23, 08:51 AM
Does that fitting rotate in any direction like the original fitting?
Dan
Old 04-15-23, 12:46 PM
$8.75 - https://www.aircraftspruce.com/catal...s/04-02145.php
Old 04-15-23, 04:22 PM
It appears that the fitting is rigid when you tighten it up, if so that is entirely different than the ones in the P models
