Unread 02-10-23, 10:39 AM
pwolfehagen pwolfehagen is offline
pwolfehagen is on a distinguished road
Fuel Pump Part Numbers - T337F
I have a bad pump on the front and figure the rear is not far behind. I would like to find an overhauled pump to install up front now. And then have the bad one rebuilt to be installed on the rear at a later date.
The Cessna parts catalog calls out 629373-1A1.
Textron says this number has been superceded by 655921-2A2.
The actual pumps installed on the plane now are 634263-1.
Does anyone have experience with these part numbers and what will actually work?
Paul
N1741M
Unread 02-10-23, 01:45 PM
According to Mikes Aircraft Fuel metering service and QAA in Tulsa…they’re all the same pump on the NA 337s. Expect 4 weeks and an AMU for overhaul. I can recommend Mikes shop…give them a call and ask about 337 fuel pumps.
Last edited by Learjetter : 02-17-23 at 11:41 PM. Reason: Clarify all NA 337s use same pump
Unread 02-10-23, 07:28 PM
Frank Benvin's Avatar
One for sale on ebay
https://www.ebay.com/itm/13434467146...3ABFBMxpPk3cdh
1967 337B
Unread 02-10-23, 09:42 PM
Sometimes the shop might have an existing pump already rebuilt on the shelf and you can do an exchange if you’re in a hurry.
I have had good luck with Aircraft Accessories of Oklahoma.
Unread 02-11-23, 12:16 PM
Yeah, went with A A of Oklahoma. They did not have one on the shelf but said they could rebuild mine with a 5 day turn around. Sent it off yesterday.
I was not able to locate an exchange anywhere. Prices ranged from $1100-$1400 for the rebuild. Turn around times varied from 5 days to 6 weeks.
Paul
N1741M
Unread 02-13-23, 08:48 PM
B2C2 B2C2 is offline
Hi, I had to replace both pumps in my 1969 T337D. It turns out Weldon makes a brand new pump for my aircraft. the PN is 18000-B 28V and it is $885 on aircraft spruce. I'm not sure about the PN for yours but If you haven't done this yet I would recommend going this route. Mine both work very well.
Unread 02-17-23, 08:29 PM
Joes Joes is offline
Turbo pump is different than normally asperated
the designation of t337f would indicate a turbo engine, if so the turbo pump uses the upper deck pressure to determine the amount of fuel to the injectors. N/A is gear driven. Two different pumps. If you find an older pump during the rebuild they will bring it up the the latest revision, but check with them before. QAA has done two for me in last 12 mo.
