Unread 08-09-20, 05:39 PM
A new Skymaster Owner enters the forums
Greetings to the membership! I've only recently become a 337 convert, coming from a long history of owning Barons, 310's, Bonanzas and the like.
I bought a 1978 P337H that was owned by a doctor for 32 years. The maintenance looks good - maybe I won't complain as much when I pay my doctor bill next time.
The Pressurized Skymaster II has boots (in good condition) and a hot prop on the front, but no hot prop on the rear. I guess the exhaust naturally keeps the ice off the rear prop? It has a provision for a hot plate, but none was included with the sale. Anybody have one lying around?
First trip home was 540nm on a 132 heading flown at 17.5K. Flight averaged 205 knots and 28 GPH. Plane could of performed even better, but I ran it well rich of peak as I'm told I should with turbos. Even some slight leaning would have saved 2-3 GPH as my TITs were low at about 1350 vs. a 1650 max. As I get to know the plane, I'll try different leaning strategies.
Aircraft was purchased with a known fault of the rear alternator not charging. Once I was home, I pulled the front cowl and checked the voltage regulator (VR). It showed good DC voltage on the red bus line ("D" line) and the blue field line about a volt less, as it should be. Every thing points to a bad rear alternator. Although...
Rear alternator was changed at the last annual and looks brand-spanking new, which makes me suspect a bad connection between the blue field wire coming from the VR and the alternator. I need access to the alternator, but can't just from removing the cowls.
The service manual refers to removing interior panels to gain access to the rear firewall service port, but doesn't give any directions on how to do it. I'm sure I could start taking things apart, but I'd much rather have photos or a guide so things would hopefully go more smoothly. Any advice in this regard would be much appreciated!
EDIT: Gaining access to the rear engine was a cinch. The problem is trying to work in 109 degree Texas heat (hanger is full again!). It was easy:
Three interior panels on the rear wall come off in seconds (they were velcroed in my plane), then the engine access cover has 8 3/8" bolts. Took maybe three minutes to gain full access. Photos in a later thread!
Unread 08-10-20, 12:19 AM
JeffAxel JeffAxel is offline
pictures, or it didn't happen! As to getting to the rear alternator, take the interior coverings off the rear wall of the cabin and there is an inspection plate you can remove to get access to the rear alternator and magnetos. What tail number did you buy?
Unread 08-10-20, 11:07 AM
Can't for the life of me understand how to post photos here. None of the photo options I'm used to seeing in other forums! And most of my pics exceed the 1MB limit.
Unread 08-10-20, 11:11 AM
Here is a pic of the CNX80 showing 210kts. I also attached the speed/altitude printout from the flight.
Unread 08-10-20, 07:21 PM
Nice, saw the advertisement. Do I remember that both engines were very high time? I was tempted to call our local engine shop (Premier Aircraft, Troutdale OR) to see what overhauls would cost for that plane but the ad was gone before i got a chance to call. Have fun with it, and I would suggest getting a Parts Manual and a Service Manual, very helpful items to have.
Unread 08-10-20, 07:50 PM
rrolland rrolland is offline
Congratulations! Enjoy flying the airplane. Looks pretty good.
Unread 08-10-20, 08:26 PM
Talking
Yep, that's the one. I was "johnny on the spot with cash" or I would've never been able to buy it. Seller had almost 100 phone calls within a few hours.
Greatest news is that engines times were being kept off Hobbs, but I found a log entry a few years back that says the engine times are much lower. The tach time is much less, closer to 1000. Either way the engines look like they're only a year or two old. Soft hoses, shiny clean surfaces, etc. I'm gonna replace a few cylinders on the back, but the front is all solid.
May do GAMI's, they are just up the road a bit from me. Not sure what the fuel flow mafia has to say about LOP operations on a turbo.
Unread 08-10-20, 11:07 PM
Red Air Rambo's Avatar
Welcome and Congrats!
Unread 08-14-20, 01:41 PM
Looks great! How did I miss the advertisement for this one? Does anyone have it cached?
Unread 08-14-20, 01:44 PM
It was only advertised for a few hours.
I just happened to see it, and I was booked on the next flight to go get it!
Unread 08-14-20, 01:46 PM
I'm green with envy. Congrats!
