Unread 07-31-20, 06:15 AM
mikezen mikezen is offline
mikezen is on a distinguished road
Riley Super Skyrocket !
Hi,
I'm Michel Heintz, french new member of this forum (living in France).
For a long time ago, I have ever been very fond of Skymasters and, in particular, of Riley Super Skyrocket conversion.
Now, I'm about to purchase such a plane (purchase agreement signed, prebuy inspection in progress), though some people advise not to do so !
Are there any Super Skyrocket owners on this forum ?
If yes, is it really a bad idea ? Are they effectively money-pits, when they are flown enough frequently and well maintained ?
What about their reliabiliy ? Is it really so bad ?
Does rear engine always overheat or is it a matter of engine management ?
I know their fuel consumption is higher and payload lower than normal Skymasters, but in french we say "when you love, you don't count !"
One last question : the plane I look at isn't equipped with de-icing boots, is it possible to add them, though the presence of required Horton STOL kit (STC SA937CE) ?
Thanks for your answers !
Unread 07-31-20, 11:29 AM
Yes, deice boots can be added to the Horton STOL wing cuff. The real question would be, is the aircraft already "PLUMBED" for boots? If it was plumbed from the factory, has all the vacuum pressure lines already installed but never had boots or the boots were removed, then it would be cost effective to add the boots. But if the aircraft is NOT plumbed, in my opinion it's not going to be cost effective to retrofit the application.
Remember, NONE of the Skymasters ever built were certified for icing conditions
Unread 07-31-20, 11:42 AM
Thank you Herb
Unread 08-01-20, 11:07 AM
rrolland rrolland is offline
Michel:
I own a standard Riley Rocket which is the same aircraft as the Super Rocket with the exception of the engines. The systems are the same, the complexity the same.
If your aircraft is flown regularly and maintained appropriately, it will be reliable. And an incredible performer with the extra power. Single Engine rate of climb should be in excess of 500PFM.
The same drawbacks will exist: it is tight under both cowlings and access often requires removing other components and...patience.
You will need to find a mechanic who does not mind the challenge.
Payload will be in exchange of range. This is true of the Rocket as well but more so for the Super Rocket. Some of the Super Rockets have limited payload left at full fuel. So the payload comes off the fuel load.
It all depends on your mission.
Enjoy the Super Rocket!
Richard
Unread 08-01-20, 11:47 AM
Thank you for this positive testimony !
Unread 08-01-20, 12:00 PM
Red Air Rambo's Avatar
Hi Michel, a friend had one and he loved it...you will too! His ran a little hot on the rear and He added the cooling kit from Owen Bell which consists of about 3 more vents and an added scoop...but every plane is different so fly it first...if it made it this long without anybody adding it then its probably good. +1 one on everything Richard and Herb said. it's a plane that falls into the hot rod rule of "There's no replacement for displacement" lol.
Have fun,
Brent
Unread 08-01-20, 12:26 PM
Smile
Thanks Brent !
Unread 08-04-20, 11:53 AM
JimC's Avatar
JimC JimC is offline
They're the same engines as the Cessna 340, so you can expect maintenance costs to be similar.
340s can cost upwards of $350,000 so owners aren't as surprised when they have a $25,000 annual.
337s often cost less than $100,000 so owners can be more surprised when an annual costs $25,000. (If a Rocket costs less than $100,000 it needs a lot of work!)
I've owned both a 340 and a 337. They each have their own uses. But don't expect one to cost less than the other.
Unread 08-04-20, 03:31 PM
Thank you Jim !
