Unread 03-06-20, 05:25 PM
Help with EGT Probe and a Suggestion on Fire Extinguisher
1. I'm having trouble finding the EGT probe that is clamped on the exhaust pipe of the engine, feeding temperature to the EGT gauge. Looks as shown in the picture below. Cessna PN is C668501-0110 (the PMA version is Alcor 86156 but it's no longer made). Any info would be appreciated. Aircraft Spruce sells an MM-112 but not sure it works. Thanks.
2. In a post years ago I suggested Halon hand-held fire extinguishers for the cabin, as being far superior to the conventional powder extinguishers, which make a mess and impair visibility to the point where it's hard to fly the airplane. They are expensive, however, with $213 being the lowest for a suitably sized unit (Halon is no longer manufactured so these items use reclaimed Halon). That led me to investigate Halotron units. They seem to perform like Halon units but at lower cost. I was focusing on a Buckeye 70258 on Amazon at $141 until I found it at WebstaurantStore.com for $87. At this price you should consider it if you either don't have one in the cabin or have the powder type.
Unread 03-06-20, 09:34 PM
Ernie, right after I purchased my 337G in September, the rear probe failed on the way home. My mechanic replaced it with this probe: Aircraft Spruce ALCOR BY Tempest EGT/TIT Type K Thermocouple & Clamp 3-3/8 Max
My airplane has the optional Cessna Fire Extinguisher under the seat. No age, date, or gauge. So, I replace it with a like-sized bottle. The bracket was different, but my mechanic changed it out in 15 minutes.
I live in a small town, so I took the old bottle into the fire station and discussed it with them. It turns out there was a young Air Force firefighter veteran! He helped me chose a replacement through Aircraft Spruce: H3R Fire Extinguisher Model A344T.
Unread 03-09-20, 01:41 AM
DrDave DrDave is offline
I went to the local fire extinguisher/safety equipment store and replaced all of my dry chem extinguishers with Halotron clean-agent extinguishers. The 2.5lb model was $118. The best part is that they sold me several re-conditioned units for half-price. The 5lb re-con ones were $90. That's a deal. I did buy a couple of big CO2 extinguishers for the shop/garage/hanger.
Unread 03-09-20, 02:57 PM
Hi Ernie....
I have been doing a little research on these EGT probes as my front engine is out for overhaul and I would like to replace as many of these probes as I can.
So what I have learned is the same as you as far as the PMA Alcor 86156 no longer being made. My rear engine has this probe. The Alcor 86156 is a Type "E" probe. I have no idea what that means (vs. the seemingly more common Type "K" probes) but the Spruce probe you mentioned is also a Type "E" probe. The Universal MM-112-1 and MM-112 differ only by the connector on the wire lead, otherwise they are identical. I just purchased two of the MM-112-1 EGT probes hoping they will work.
I spoke with both Alcor and Universal on the phone and they were both very helpful. From what I understood, there is a resistance difference between the old Alcor 86156 and the new Universal probe. They both agree the Universal probe will cause needle movement on our old Cessna EGT gauges that I believe you and I have the same units in our 1973 C337G models. My old Cessna EGT gauge has adjustable pointers so I can align them after leaning which makes any changes during cruise obvious. I'm hoping that the Universal probe causes enough movement on our old Cessna gauges to make them useful. I will not know for another 6 weeks or so if they work.
The Type "K" probe that a previous post mentioned works with my JPI EGT/CHT display. Those Universal EGT probes I have had success with in the past.
Let us know if you have any other success with this.
Good Luck,
Ed
Unread 03-10-20, 01:54 PM
For PatrolPilot: did the Aircraft Spruce type K probe work with the original factory gauge? The original is a type E (which I believe has one lead grounded) and I was under the impression that a type K won’t work with the original gauge.
For Ed: when you are running again, let us know if the probe worked.
Unread 03-10-20, 04:26 PM
Will do...
Unread 03-11-20, 08:06 AM
Ernie, yes, it is working. I've been at Center Line Aero (PKV) the last several days, let me talk to Lou about these probes if you don't mind as he might shed some light on them as he keeps a variety of probes in stock.
Honestly, I would think that the difference between the two lead lengths would necessitate a difference between the two.
Originally Posted by The C336 Skymaster Story
To aid in identifying a failed engine" Charlie Tanner's power plant group designed a microswitch assembly that sensed fore and aft engine motion in the rubber engine mounts. With a rearward motion (from the drag of the windmilling propeller) a red warning light would illuminate in the related propeller knob. Although the aforementioned microswitch unit multiplied the actual engine movement by a factor of six, there were still false warnings that would prompt an unwarranted engine shut-down. Thus the system was removed in favor of pilot reference to engine and EGT gauge indications of power failure.
You kind of hit the nail on the head. The only thing this gauge is supposed to do, the why behind its installation, is indicate that the engine is hot or cold. We are flying, the only, that I can think of, twin-engine piston airplane where the AFM or POH requires EGT to be used to identify an engine failure.
  • The three identifiers
  • RPMFuel Flow
  • EGT
Give the location of the single probe, after all the exhausts stacks join, I think it is a real mistake to use this instrument to define anything related to peak EGT operations. I know Cessna covered its use for leaning with a paragraph, but the single probe has a lot of promise for compromising a cylinder.
The adjustable knob on my left EGT managed to stop having any effect. I suspect that the gearing inside is plastic, so it just shows full scale hot or cold. The Insight G4T is Primary EGT replacement, and I'm kind of considering pulling the gauge completely. I notice that passengers tend to look at it with that front side full "hot."
I started flying the P337G in 1975 out of Harlingen for Air Central, a 135 Operator, with a majority of our flights into Mexico. My training and advice were to use Fuel Flow for engine management and keep the EGT pointers "near" together for aesthetics.
