Unread 02-27-20, 09:41 PM
rebuild fuel selector valve
looks like I am going to need a fuel selector valve rebuilt. who does these for 337? (I haven't had chance to call McFarlane yet; I see they rebuild others.)
Unread 02-28-20, 05:54 PM
If it’s only leaking then it’s easy to replace the cork seal. But good luck getting that part. However, getting a sheet of cork and making the gasket is cheap and easy.
Unread 02-28-20, 11:51 PM
It's not providing a positive cut off of fuel flow. Wish it was easy as just needing cork gasket. Internals will need to be serviced. Are there any flexible rubber/plastic life limited internal parts? Is there a service kit?
Unread 03-01-20, 04:02 PM
DrDave DrDave is offline
I just went through this. The issue of leaking past the valve is from the little balls not sealing on the seats. The selector valve has a small well in it that can collect water. I think this contributes to the problem. The ball is held against the seat with a spring that is likely rusted. There will also be some rust on the seat that is causing your leak-past. You can remove the valve and see the ball/seat assembly. Don't remove the little clips that hold in the spring. They seem to be impossible to find. If a replacement clip/retainer was available this project would be pretty easy. I was only able to find one guy that was willing to look at them. He wanted a fortune and was a bit on the grumpy side.
I had one guy that thought removing the spring and ball and re-cutting the seat was the answer. I sent him one of my valves. It just sat on his desk for two months. On close inspection the seat was not pitted it appears to have surface rust that would likely clean up.
I think an ultrasonic cleaner would be a good start.
I found a pair of used valves that were not leaking.
Unread 03-01-20, 08:47 PM
Has anyone used B & S in Wichita lately?
Unread 03-02-20, 09:19 AM
I have been studying the valve drawings and come to the same conclusion myself about either corrosion (most likely) or some grit stuck in the ball/seat area. Also, been doing some research and B&S in Wichita is on my call list.
Unread 03-05-20, 08:34 PM
I have one of the old valves on the shelf. I'll take some pictures so you can plan your attack.
Unread 03-05-20, 09:56 PM
sounds great. surely there must be a matching internal c clip somewhere (I've been shopping internal c clip assortments-a kit with various assorted sizes very affordable) or if part is serviceable, clean things up and reuse.
