Unread 09-03-17, 07:42 PM
JimC's Avatar
JimC JimC is offline
Gross increase with STOL?
If you look at the old Robertson brochures, they claim a GW increase for A-E models. Is this a typo, or do you really get a GW increase? Can someone with one of those models actually confirm the increase?
Some posts on this site claim a 100lb GW increase with a Horton kit, some say there's no increase. Does anyone have the paperwork that shows the real answer?
http://www.337skymaster.com/messages...5&d=1240974251
Unread 09-04-17, 10:43 AM
Jim
It would probably depend on how the STC was submitted. If the STC did not indicate a GW increase and a W&B sheet was not accounted for you would have to go back and re-submit the form 337. May have to get FSDO involved. I can't imagine anyone NOT taking advantage of this but stuff gets through the cracks
I am not aware of any GW increase with the Horton STOL system.
Unread 09-07-17, 07:21 AM
JimC's Avatar
I was wondering if anyone with a Robertson STOL could confirm that they actually did get a GW increase.
Unread 09-28-17, 02:09 PM
JimC's Avatar
I found at least one 337D that most definitely got a GW increase to 4700 lbs with a Robertson STOL. Landing weight was raised to 4465. The brochure only advertises a raise to 4630, but this one somehow got to 4700.
Unread 11-22-17, 02:06 PM
B2C2 B2C2 is offline
I have a Robertson equipped 1969 T337D with the original STC paperwork. the differences in GW increase are for NA vs Turbo models.
NA GW is 4630
Turbo GW is 4700
This is true for all models A-G
for my aircraft all weight above 4500 must be carried as fuel, and max landing weight is 4465.
I can scan and post the full STC if you would like.
Ben
Unread 11-23-17, 09:26 AM
JimC's Avatar
A scanned copy of the STC would be much appreciated.
