Unread 04-18-17, 11:45 AM
JB78382 JB78382 is offline
JB78382 is on a distinguished road
Magnetos
Ok, so here I sit with 700 hr stock normal I.O. 360 engines. The ignition seems to be running very good...BUT...The current trend seems to be "send the mags off at about 500hrs" for overhaul. Is this a good idea? Is it different between Bendix or Slick mags? I have heard the opinions of two experienced IAs, now, I'd like to hear other owners' opinion.
Unread 04-19-17, 08:59 PM
Post moved here from Mechanics subject
Because the member wasn't specifically looking for a facility it will be seen by more folks here for responses
Unread 04-20-17, 12:40 AM
Well, thank you.
Unread 04-20-17, 01:19 AM
AP AVM AP AVM is offline
Just a newbie question:
How many magnitoes are on IO 360 engines and of what brand mostly.
Unread 04-21-17, 08:41 PM
Two mags per engine; typically Bendix but some have been changed over to Slick
Unread 04-24-17, 11:32 PM
Thanks Herb. I thought there were 2 Mags/engine but wasn't sure.
Unread 04-25-17, 03:50 AM
DrDave DrDave is offline
How does it do with a LOP mag check in flight?
Unread 04-25-17, 04:16 PM
jchronic jchronic is offline
Just sitting here I can't cite the reference without looking it up, but in my case - operating in compliance with Part 135 rules (terms of my survey contract) - my mags (Bendix) come off for inspection (IRAN) every 500 hours. May not apply under Part 91; again, unsure whether it's a recommendation or an actual AD....
Joe
Unread 04-25-17, 11:01 PM
Recommended for Part 91, not required
Unread 04-26-17, 12:57 AM
Under Part 91 it is recommended, the TCM I.O. 360 owners manual says Bendix mags "should" or "need" to be overhauled at 500 hr interval.
Unread 04-26-17, 12:02 PM
LostKiwi's Avatar
LostKiwi LostKiwi is offline
Whats the cost of overhauling a mag vs installing an electronic ignition?
Leighton.
Unread 04-26-17, 01:17 PM
$750 to $1000 in most cases. Electroaire are in the $3000 range
