Unread 08-18-14, 10:53 PM
jchronic jchronic is offline
Reg Number Size/Location
Perhaps a somewhat naive question, but in the slow process of repainting my airplane I want to move the reg numbers off the vertical stabs and place on the boom sides, where I see others.
The airplane having sported a camo paint scheme up to now and considered a 'display' airplane, the numbers on the tail were 3" high. According to Part 145 (I think it is), now that the airplane is being repainted the numbers have to comply with the 12" requirement. By my measurement, 12" numbers won't fit on the boom sides without some 'wraparound.' So do I fudge slightly smaller numbers, or accept some wraparound...or?
Since I operate in and out of the ADIZ a good bit, want to stay as legal as I can.
Thanks -
Joe
Unread 08-18-14, 11:48 PM
If your aircraft is more than 30 years old then you can keep the 2" numbers...even if repainted. But can't use that for ADIZ crossings.
http://www.aopa.org/Pilot-Resources/...umber-Markings
Enjoy,
Rob
Unread 08-19-14, 09:21 AM
Thanks Rob. So I guess the Skymasters I see with numbers on the boom sides are maybe using less than 12" numbers under the more than 30 years old provision?
Joe
Unread 08-19-14, 11:35 PM
The FAR leaves a lot of wiggle room.
Unread 08-23-14, 01:04 PM
JamesC JamesC is offline
I left the small registration marks on the booms and put an oversized version under one of the wings. If I ever have to wing waggle beside an F-18 they won't miss it.
https://flightaware.com/photos/view/...rt/date/page/1
Unread 08-23-14, 02:41 PM
I went through ADIZ hundreds of times between So. Florida and the Bahamas over a 15 year period with the numbers on the booms and never had an issue.
