Unread 03-24-12, 10:40 PM
kdiel11 kdiel11 is offline
kdiel11 is on a distinguished road
N2334S Gear up landing in Dothan, AL
Just wanted to let you guys know that my MEI friend and I had to perform a gear up landing at DHN this afternoon. We could never get the landing gear to extend. It would only open up the gear door and let the gear flop out. When we tried pumping them down, we met with loads of resistance on the handle. My take on it was that one of the hydroelectrical valves for the power pack would not open to energize the lander gear hydraulic actuators. We tried for over an hour to get it to work. Don't know how many gyrations of master switch and landing gear handle combination we did trying to get it to come out. At one point my friend said he felt the gear even make contact with the forward structure when he did a positive g maneuver but they failed to latch (if they can even do that without hydraulic or emergency power). So we traveled over to DHN did a couple of flybys to get everything straight on where they wanted us to land and then came in on the back engine and put it down at around 55 mph. We might have been a bit vertical at the end, slid for about 200 feet on the sod next to the runway without further incident (if that wasn't enough). My friend pulled the rear engine off line just before impact but it still bent the last 6 inches of both blades on back. So that engine will still have to be torn down and a sudden stoppage inspection completed on it. Frankly, I don't know if I will return it to flying status. I have no problems going back out to fly, just don't know how much it is going to cost. If you dont recall, I fly without insurance on the plane. Please......no I told you so's right now! So I may end up just parting her out. More to follow on that point. Can anyone give anyother advice on what we could have done while airborne? KD
Unread 03-24-12, 11:15 PM
All I can think of right is that I am really sorry to hear of this tragedy. You must be just totally exhausted mentally and physically going through this. It is good to see no concerns of injury to either of you. It is a very strong airframe and it sounds like it kept you safe. Take a deep breath and give yourself some time to absorb all that happened so that hopefully you can determine what happened. Hang in there.
Unread 03-25-12, 12:45 AM
Thanks for the well-wishes. Hopefully, it won't be too expensive to repair. The biggest thing is are they going to consider the engine as sudden stoppage which I think they will even though we had shut it down prior to contact to the ground. The damage to the prop, to me, only proves it was just spinning down. However, I imagine they still will want it tore down. What a shame....that was my under 500 hour out of factory reman engine too. Kd
Unread 03-25-12, 01:57 AM
I think some one else posted on this site that they banged (kicked) the hyd pack to make the shuttle solenoid un-stick. Additionally, I hear a cargo pod will keep the air frame off the ground while gear up.
perhaps negative g's would have worked to lock the mains down...but who knows.
Unread 03-25-12, 09:53 AM
KD, if you get this before noon today (Sunday) give me a call at 305-562-0565. After 2PM and for the next 2 weeks call me in the Bahamas at 242-367-8326.
Ernie Martin
Unread 03-25-12, 10:51 AM
I think some one else posted on this site that they banged (kicked) the hyd pack to make the shuttle selinoid un-stick. Additionally, I hear a cargo pod will keep the air frame off the ground while gear up.
That would have been something to try. I know it is on the pilot's side somewhere, but not exactly sure where. It does sound as though that was our problem. We did perform dive pull-outs (positive g's trying to get them to lock) and my friend thinks he heard them hit the forward stop but they never locked. Another thing might have been to see if it released after we shut down the forward engine. KD
Unread 03-25-12, 11:57 AM
Tony
Sorry to hear about your unfortunate mishap and glad to hear you are ok.
In discussion with Tom Carr a couple years ago regarding landing gear failing to come down, he had said if this happens to shut the master switch off for 5 or maybe 10 minutes. The reason you need to do this is to let the solenoid in the power pack cool down.
If it does turn out to be a faulty solenoid, it can be changed in situ. I had to change mine. They are fairly expensive but after some research I found alternate part numbers which brings the price down considerably.
Unread 03-25-12, 05:24 PM
I think positive g's work for the nose gear, but negative g's might work for the mains. Reason, nose gear must come down and aft to lock, while the mains must go forward and down to lock. That's why I think positive g's will push the main gear aft towards the retract position..but negative g's might push the mains forward to the down and locked position.
