Unread 03-04-10, 12:30 AM
N5ZX's Avatar
N5ZX N5ZX is offline
N5ZX is on a distinguished road
one break inop...other is fine
> Yesterday I went out to the hangar to run the engines for a few minutes.
> In the process of doing so, I discovered that my right break is inop.
> Absolutely nothing.
> Left side holds great....no problem at all.
> Right side is completely effortless....all the way to the stops....no
> resistance.
> There is no brake fluid on the ground.
> Nothing squirts or sprays when I press the pedal.
> The pedal returns to the upright position with no problem....which I
> think tells me the spring linkage is intact.
> And when I press on the pilot-side right pedal, I can see
> corresponding movement in the cop-pilot right pedal.....which I think
> tells me that the cross-linkage is intact.
> Again....left side break....perfect.
> Any thoughts?
Cole
Unread 03-04-10, 09:50 AM
Roger's Avatar
Roger Roger is offline
Welcome to the world of Skymaster ownership Fuel guages, doors and brakes. I will never forget landing in Nassau and being rushed to turn off right to clear for a Delta arrival. Pushed both toes and immediately swung left, as the right was completely dead. So to make the right, I did a quick 270 to the left and pulled off.
You have to picture the Bahamian controllers voice that said "Man, what the hell was that" ?
The brakes are totally independant. The fluid is probably pooled in the belly. MIght need a new seal on the master.
Unread 03-04-10, 11:10 AM
N5ZX's Avatar
Peachy.
Thanks for the insight.
I'll go look.
(see...I CAN make brief postings too)
Cole
Unread 03-05-10, 11:22 PM
JeffAxel JeffAxel is offline
it turns out that Cessna mounted the right brake master cylinder higher than the left one. If the seals in your parking brake (located by the pilot's left knee) are bad, the right master cylinder can drain into the left one leaving you with no right brake. If there is no apparent leaking by the right master cylinder, but a lot of 5606 below the left one, the fix is to replace the "o" rings in the parking brake manifold. If there is leaking apparent at the right master cylinder, then I would start there first. Resealing the parking brake manifold is what solved this problem for me when I had it a few years back..........
Unread 03-06-10, 09:04 AM
N5ZX's Avatar
Thanks, Jeff.
I'll double check the parking break.
My biggest head scratcher was that there was NO fluid anywhere.
Not under either master cylinder. Not on the floor panels. Not on the ground. None.
With the aid of a hangar-neighbor who happens to be an A&P and by even greater stroke of good fortune, has 15 years of experience rebuilding 337's, I topped off the Right Master (it was apparently about 2/3) empty.
Still no right break.
Our next move was to reverse-bleed the right break system.
10 minutes later...perfect right break.
So I had a problem. I found a solution (with the help of a lot of very nice folks ...THANK YOU ALL)
Now all I lack is figuring out the cause.
Break fluid doesnt evaporate so it had to go somewhere.
Since it isnt enywhere else...I gotta assume that the escaping fluid is pooled in the belly as suggested by Roger.
George Brown (my hangar neighbor) says that there is a swivel union where the gear rotates into the gear bay when retracted and that can weep fluid and make it "vanish".
Whereas I certainly have no data-points to argue against that possibility, I have difficulty imagining a "weeper" taking my break from good to gone seemingly overnight.
Needless to say....I'm racking up the hobbs time just driving around the taxi-ways waving at people as they gawk and greet me with the "What the heck is that?" look on the faces....which I am growing accustomed to...and LOVE IT.
Thanks again everyone.
Cole
Unread 11-14-15, 10:46 AM
bking bking is offline
bking is on a distinguished road
Just had the same problem occur and could not find a parts breakdown for the parking brake assembly in either the parts or service manuals. Do you by chance have the O ring part numbers you could share?
Unread 11-14-15, 11:50 AM
P/N should be MS28775-010 it takes 3 you can find the manual at Parker.com . You will also need O rings for to fittings ,you have to remove them to get the shaft out
