Unread 10-06-09, 09:21 PM
Todd Gessel's Avatar
New Engine
I'm putting in a new re manufactured rear engine from Air Power. While I'm at it, it's getting new hoses, new vac pump, new Lord mounts, F-M enterprises oil filter adapter, new drain plug, neoprene valve cover gaskets, new baffling, new prop and governor. The exhaust system and engine mount has been visually inspected. This airplane has about 800 total hours on it.
Does anyone have any advice or comment about anything else that should be considered, inspected or done while I have the rear engine out? Is there any potential SID inspections or tests I could or should do with the engine out?
If anyone is interested, I gave $29,625.00 for the engine, $1,012.00 for freight (round trip), $12,100.00 core deposit, $695.92 for (4) Lord mounts, and $354.64 for the vacuum pump.
Thanks, I really appreciate everyone's participation in this great resource for Skymaster enthusiast.
Unread 10-06-09, 09:38 PM
There is a draft SID to remove the tubular engine mount and do a magnetic particle or penetrant inspection of all welds. Whether it will survive scrutiny and become a published SID remains to be seen, but inspecting the tubular mount is always a good idea and dye penetrant inspection of the welds should not cost much.
Unread 10-06-09, 10:10 PM
Big money Todd, is this aircraft new to you? Where did it come from? Wow only 800 hours TT?
I used the F&M and they seem to be working great. Can't think of anything else right now.
Unread 10-06-09, 10:54 PM
Thanks Ernie for the info on the dye penetrant inspection, I was unaware of that test.
Herb,
This airplane has been in my family for many years, in storage in a hanger. I know 800 hours is pretty incredible. It's got to be one of the lower time Skymasters around. After I earned my multi-engine rating, I started flying it in January ('09). It's an awesome aircraft. Unfortunately, I had a main gear door actuator fail and result in a main gear up/rear prop strike. Thus, the new engine. See my posts from July. Fortunately, the insurance company is covering part of the engine cost.
Unread 10-07-09, 10:00 PM
Guy Paris's Avatar
factory reman.
Todd,
Are you getting the heavy case upgrade,? Looking at my old paper work (05/06/04) it was called:
CD1-TCM Core upgrade $1000.00. guy paris....
Unread 10-08-09, 01:00 AM
As I understand it, I am getting the heavy case, the VAR crank, and the new style starter. This is just off the top of my head. I don't have the paperwork and notes with me right now for all the details. I am happy to share any of this info in more detail if you're interested. Also, if there are any pictures anyone would like to see of the process, I'm happy to post them too.
