Unread 03-29-09, 07:47 PM
Visual determination of fuel on board
I have never owned a Cessna product before but I don't have any confidence in gauges no matter the bird. However, other than beginning every flight with full tanks how do you determine the fuel you have on board. For some of the singles I know there are "calibrated" dip tubes that are inserted into the fuel fill entry. And for my Seneca and Beech there were tabs that you could see.
But given the dihedral of the P337 and its single fill tube,it may be that the half full condition may not show up on the fill tube.
Can any of you give me a suggestion on what you do for this.
Dave Dillehay N84E
PS. Sorry if this has been answered before but the search function only shows gripes about gauges!
Unread 03-29-09, 10:25 PM
My first choice, like yours, is full tanks for each flight. I was taught to always fill the tanks when you return before you put the bird away. Having owned the current Skymaster for the last 33 years you sort of get to know all the characters of the particular aircraft. I too do not use the gauges as the only source of information. There are other stats that should be considered. First, my favorite TIME. Know your fuel burn and know how long you have been flying and how much time you have left. I also use the feature on the Garmin 530, essentially time again, that allows you to input the gallons and it calculates the fuel burn based on parameters that are user loaded given time flown. The other important stat is VISUAL. I still make a habit of visually looking in the tanks from the service port to make sure nothing funny has happened. This is especially important when parked outside on an unfamiliar ramp. Again when you have the FBO top the tanks you better make sure what tanks they topped and if they really did and if someone hasn't fooled with something. Just because it says 85 gallons on the ticket doesn't guarantee the tanks are full. Many times the FBO tops the inboards (normally the mains on a lot of aircraft) and not the outboards. This may be ok in the long run but if the mains are less than 1/2 I won't talk off. I will make them bring me a ladder and check the service port myself. Also because the mains are 2 separate tanks, interconnected by 3 couplings, if the tanks are filled with a high volume dispensing fuel valve the tanks will not have adequate time to equalize and your mains will not be full.
So in summery TIME is my gauge along with the instrument gauges (after 33 years I know what they read) and VISUAL check. Dipsticks will work in the inboards but you're not going to get a good reading with sticks in the mains.
I always like to use the upper half of the tanks instead of the lower half.
Unread 03-29-09, 10:26 PM
You use a dip tube which you calibrate per the instructions with the tube. It won't register below roughly 1/2 full, but it's quite accurate above that. In my 1973 normally aspirated 337E with long range tanks, a thin film visible under the fill port indicates you have 30 gallons in the tank (max 62). Greater fills can be accurately guaged with the tube.
Unread 03-29-09, 10:38 PM
Hi Dave....
My model is a 1973 337G (no turbo and no pressure). Fuel determination can be a bit of a challenge for these planes. My plane has 4 tanks in each wing and one place to fuel all four way out towards the end of the wing and then the fuel SLOWLY feeds down to the inboard tanks. A calibrated dipstick would not work on my plane because I would only be dipping the outermost tank. I don't know if you have been reading about all my fuel gauge troubles lately but up until a few weeks ago I had very good luck with my gauges being very accurate and dependable. I do however never rely on them.
My methodology for determining fuel quantity is quite rudimentary but very dependable. When I top the tanks, making sure to take my time so the fuel has time to feed down to the inner tanks, I simply subtract 20 gallons for every hour I fly. Realistically the fuel burn is more like 16-18 gallons per hour but 20 makes a nice conservative round number guesstimate. You will most likely need to take the time to "get to know" your airplane and see precisely what it takes at the pump when you top it off. I find that I can usually be within 2 gallons when I fill her up. Just make sure your first few flights are with full tanks and learn what she uses and then add a little extra per hour for your flight planning and you will be fine. As I said, rudimentary but accurate enough.
I will reiterate once again, top her off SLOWLY and give the fuel time to feed down the line. The fuel pumps are ALWAYS faster than the plane can take the fuel. I personally will go back and fourth between each wing at least twice and occasionally 3 times if I was too impatient while SLOWLY feeding the tank the last several gallons.
My gauges always made a nice X-check with my math and I hope to have those back on line within a few days!
Hope this helps!
Ed Asmus
Unread 03-29-09, 10:43 PM
Oh yeah...
One more thing. Nobody fuels my airplane without my direct supervision. I prefer to do it myself but if the FBO must do it, then I am there period. Nobody secures my fuel caps except me!
Ed
Unread 03-30-09, 12:27 AM
I beg to differ with Ed, but I have exactly the same aircraft and you can indeed use a calibrated dipstick as long as you recognize the limitation, specifically that it won't measure below 30 gal per side. Above that, it's very accurate. Most of my flights are over water, adequate fuel is more critical to me than for most other Skymaster pilots, and I spent considerable time researching the system and making the information available in the Fuel Supply Management page at www.SKymasterUS.com
Other techniques, like supervising fueling and keeping close tabs on time, are critical, but for me the most important is climbing on the wings and using my dip tube.
Unread 03-30-09, 08:20 AM
Ernie is correct. I was thinking in terms of the entire wing. One other thing I would like to add for Dave is to make certain you understand YOUR fuel system on YOUR particular model of Skymaster. These fuel systems vary greatly depending on the model!
Thanks for keeping me on my toes Ernie. I appreciate attention to detail!
Ed
Unread 03-30-09, 12:31 PM
Dear Ernie,
Just so I fully understand (given the model year differences) my 73 P337 with 128 gal capacity, should be the same as your 73 in fuel tankage. That is, if I can see fuel below the fuel tube, then I have at least 30 gallons. I will of course confirm this myself, but correct me if I am wrong.
Dave Dillehay
Unread 04-29-10, 09:50 PM
tkirklindale's Avatar
tkirklindale tkirklindale is offline
tkirklindale is on a distinguished road
engine gages
is there any stc engine gages out there for the 337 ??
