Unread 11-30-07, 10:21 AM
Guy Paris's Avatar
Cool Control Column Ribbon....
The ribbon wire that goes thru the control column. I had problems
several years back with one of the switches on the control wheel.
I am having trouble with the map light now. If memory serves me
correct, I think my mech used another wire that ran thru the
ribbon to remedy the problem back then. I have noticed on other
337's a different arrangment, a heavy coiled wire coming out of
the lower panel and I believe going to the control wheel. Is there
a fix for other than the ribbon wire or is it best to try and replace
the ribbon wire? thanks, guy, the old 72 driver....
Unread 11-30-07, 11:38 AM
mine had problems a few years back.
was replaced with multi conductor cable
with each conductor shielded. never have had a problem since. took less than 3hrs
to fix.
Unread 11-30-07, 02:22 PM
Guy
Sent you an email regarding this.
Use a multicore coiled cable, and run under panel to the grey round connector which should be by the control column.
Regards
Pete
Unread 12-11-07, 07:54 PM
Guy Paris's Avatar
Cool Control column ribbon....
Thanks for all the inputs.... guy, the old 72 driver....
