Unread 12-21-20, 02:30 PM
hayesjaj hayesjaj is offline
73G Panel Modification
I'm working up a plan for my 337G (1973) panel and am looking for options. Option one is to retain the entire structure and make new overlays (carbon fiber etc) over the top.
The alternate is to use the "nibble" method to modify the original metal panel to allow for a new CNC panel to be installed over the top of it with all instruments mounted conventionally (from the rear). This is done to preserve the structure of the panel. Does anyone have pictures of how this was done on your panels?
Either way I'm likely going to add 2x MVP-50s so the RHS will need some modification either way.
Attached is my panel's present state.
Unread 12-22-20, 08:53 AM
First class top of the line
Checkout http://www.pfluegers.com
D
Unread 12-22-20, 09:08 AM
cartrm cartrm is offline
I would be interested in carbon fibre overlays.
Let me know if you find a source!
Unread 12-22-20, 09:52 AM
I’m going to have https://www.maxqcomposites.com/ do one part for me to see how things go. Will report back.
Unread 12-22-20, 08:32 PM
Dr.Dan's Avatar
Dr.Dan Dr.Dan is offline
I'm also looking for panel covers for a 73G. I plan on making some out of ABS for now, but carbon fiber would be great in the future.
DD
1973 T337G
Unread 12-22-20, 09:49 PM
SkyKing SkyKing is offline
Do you have a photo of the ORIGINAL Cessna plastic covers before the dismantling stage? My thought is you should try and retain/maintain originality as it came from Cessna.
Unread 12-22-20, 09:51 AM
This website is not active. I’m not sure if Hal is working any longer.
Unread 12-24-20, 01:34 AM
I am finishing the install of two MVP-50Ps in my FT337GP.
Here are a couple things to consider:
If the structure behind your co-pilot's panel is like mine, there is a structural brace behind the panel. Its about where your previous fuel flow gauges were and it slopes upward from aft to forward. After taking that brace into consideration, I had about 1/8" vertical extra to play with to get the two MVP-50P's in the stack. Part of that 1/8" went to separate the two boxes behind the panel by about 1/16".
Also, allow space on the pilot's panel in front of you to place the 2-master warning and 2-master caution annunciator lights.
Additionally, the prop sync will be lost as it will not interface with the MVP-50Ps.
I used plexiglass sheets to do test cuts on. Then I mounted the plexiglass panel, and the instruments, to test the location of all the holes. After 4 iterations I got it the way I wanted, then cut the final panel.
Be sure to spend all the time necessary to research all the options for the MVP-50P. It's a very capable system and has a lot of options that you may, or may not, want to take advantage of.
Full panel during install
N337K-FT337GP
KLOU
Unread 12-24-20, 08:37 PM
Thanks Rick that is a great help! Do you have any pictures of the cuts to the original panel available prior to installing the cnc'd cover? Also, looks like ours is almost identical. Would you mind sharing the CAD for the panel?
I would be interested in the options you picked for the MVP 50 as well.
Unread 12-25-20, 11:34 AM
Glad to help.
Just to be clear, my new copilot's panel is a clean sheet re-do, not an overlaid cover. Another thing to be sure of is the allowability of a panel material other than the original material. My original panel was made from a .050 sheet of 2024 T3, so that's what I went back with. My IA at one point made a comment the panel was "structural" which led me to believe that there might be specific requirements for the composition for the panel's material. You should check that out if you're thinking of changing material for your new panel's construction.
Here's a picture of the old panel prior to removal:
Old panel, installed
This is the picture of the old panel:
Old panel, removed
This is what was behind my old panel, after its removal: Note the brace I was talking about directly above the "FWD PASS AUX AIR" switch. Note as well, where my IA located the forward engine's EDC and sensors against the sidewall.
Behind old panel
I don't have the CNC file. I worked with a great guy locally who has all the equipment, and expertise, to do the layout, testing and cutting. If the frame of your copilot's panel is the same as mine (or at least close to mine), there might not be too much adjustment for him to layout and cut yours also. There, of course, would be some shiping back and forth until you got it the way you want it. He also, made all new placards and labels for the interior and made a new "Red Ball" for the handle of the emergency gear pump shaft, as mine appeared to have been broken into several pieces and glued back together several times. All of it looks great! We are working on new labels for the circuit breaker panel now. I'll put a photo below of this work in progress, but you'll be able to see the direction we're headed. His pricing has been very reasonable. I can get you in touch with him if you like, PM me and we can set a time to chat about his work, his contact info and all the options for you to consider in configuring your systems.
Work in progress on circuit breaker panel
Rick
N337K-FT337GP
KLOU
Unread 12-27-20, 02:17 AM
california Sky california Sky is offline
california Sky is on a distinguished road
Panel upgrade
Redoing our panel in 58C.
Looking to get as much input from others experiences as possible.
After about 5 tries we are almost there with the adjustments needed to get it just right.
Going with EI instruments as a primary replacement on the pilot side.
Will post pics in the morning
Unread 12-27-20, 10:11 AM
Are you doing the CGR-30P? If so, we should talk (and I would love to fly up from San Diego and see the project!). In addition to my 337 project, my brother/parents have a 337D and want to put a CGR-30P combo into it. Unfortunately, EI hasn't done an STC for us. Are you using a DER? Any chance you could share his info with me? I think I prefer the round gauges over the square (and significant panel mods required) for the mvp-50p.
Unread 12-27-20, 11:48 PM
New link for all to see
https://photos.app.goo.gl/hA8UqvGJZawfa1gz8
Unread 01-15-21, 01:49 PM
saxbill saxbill is offline
saxbill is on a distinguished road
Where did you put the other CGR 30-p? Any chance of seeing the major alteration FAA form and supporting data for getting it approved? Want to head down this same path very soon.
Unread 01-20-21, 12:21 PM
EI instruments
Still working on the layout.
No paperwork completed yet
Just got all the instruments situated last night.
Attaching pics after I create the link.
File Type: jpeg 45AE4144-5D9B-417C-BA11-F24D9B23FE68.jpeg (884.8 KB, 2062 views)
