Unread 10-16-13, 02:31 AM
SkyMac's Avatar
SkyMac SkyMac is offline
Aux Power
Guy's I need a bit of help, next time someone has their front engine covers off can you take a photo of the aux power connections and the capacitor underneath.
I realise it is not the easiest spot to get to.
Unread 10-17-13, 11:53 AM
jchronic jchronic is offline
Dave -
I'll be over working on the bird tomorrow and will attempt to take a useable photo or two (I've undertaken doing the repaint myself that we discussed last year and the cowlings are off - it's every bit as much fun as you said it would be!).
Regards-
Joe
Unread 10-19-13, 05:41 AM
SkyMac's Avatar
Thanks Joe, many thanks for doing this.
Let me know how you get on with the painting, anything questions just ask away.
Unread 10-22-13, 09:36 AM
Dave -
After looking at the airplane the other day I realized I can't see the capacitor or really anything around the power plug inside of the lower cowling. I can post a photo of the plug & cover from the outside for what that's worth, and will keep looking to see if I can shoehorn my old digital camara around to shoot something useable inside without removing the battery and bracket.
Sorry!
Joe
Unread 10-22-13, 10:44 AM
SkyMac's Avatar
Hi Joe
Thanks for having a look, the capacitor / contactor is mounted directly under the AUX power socket, hard to get to when the engine and exhaust is in place.
I have bought a new contactor and diode board as mine were in not so good condition, eventhoguh they still worked they basically fell apart when taken out. The main reason for the photo is I was not there when it came out and I want to make sure of the mounting and placment of wires.
Unread 10-26-13, 10:41 PM
Dave-
I looked in my maintenance manual and there's an exploded view of the power plug and contactor and mount that attaches to the bottom of the battery frame. The 'architecture' of how it all fits together isn't all that clear but I can scan it and e-mail it if you like.
Re the painting, the stripping on the fuselage is coming along slowly. I've completed most of the removable parts, engine cowlings, panels, etc. For the aluminum prep I'm trying a new product, PreKote, which is a lot easier to use than the traditional acid etch/Alodyne process and a lot more environmentally friendly (supposedly). The U.S. Air Force has become a big user and advocate of it. We'll see how it holds up over a winter of low altitude flying over salt water.
Joe
