Unread 03-26-12, 01:26 AM
SinkRate's Avatar
SinkRate SinkRate is offline
SinkRate is on a distinguished road
Smile SE 336 Performance Questions
All,
I have been a lurker on this forum for a bit now and had a question regarding the performance numbers of the 336. Of course I have been to rising up, but I was searching for more detail regarding SE numbers for the 336.
Using google I came up with the following
http://i1082.photobucket.com/albums/...w/7de56e32.jpg
And if I squint my eyes just right I think I see
FE +355 FPM
RE +424 FPM
I assume that is for SL std day. Does the POH of the 336 have a section for hotter than std and various MSL SE climb rates? I was hoping that someone could post perhaps some portion of the 336 POH perf section to this forum? If not does someone have a 336 POH for sale?
Regards,
ISO
Unread 03-26-12, 08:22 AM
336 Articles for info
ISO
I don't have a lot on the 336 but there were some pretty good reviews in Flying magazine back when Cessna introduced the first Skymaster. These past issues of Flying are available on Google Books
http://books.google.com/books?id=8BV..._issues_anchor
This is the very first review that Flying did and it does give some good detail of performance.
http://books.google.com/books?id=ebV...page&q&f=false
The 336 is quite a different airplane than the 337. Cessna made many changes to the 337 based on that first few years of testing the 336. I have a history paper that was posted for the 50th Anniversary of the Skymaster last year that I will post here again. Gives all the ups and downs of the development at Cessna.
Unread 03-26-12, 05:07 PM
SinkRate's Avatar
Thank You
That was helpful, many thanks, you said in your post...
"The 336 is quite a different airplane than the 337. Cessna made many changes to the 337 based on that first few years of testing the 336"
If you have a document describing the differences I'd love to see it. Is there something structurally wrong with the 336? Based on reading some of the posts here, not sure if this is correct, but it sounds as if the sight picture in cruise is higher than the 337. According to the information I've seen, the 336 has the ability to get in and out of my home field at std day gross with room to spare, while carrying the desired payload and possessing the desired range with twin engine safety.
Looks like 37 total accidents/incidents for the 336, 12 of them fatal. I think there were 195 336's produced. Also there doesn't appear to be any of them for sale currently.
Unread 03-26-12, 05:29 PM
Here's some good reading for you. I forgot I was going to attach this earlier.
Given the circumstances in the light twin aircraft sales, a 337 is lower than I have seen them in many years. Just be careful you understand the complexity of owning a Cessna Twin Engine airplane. It is not a 182, it requires more attention to everything. Granted a 336 might be simpler but Cessna only built them one year for a reason. Be very cautious of "REALLY CHEAP" priced Skymasters. There may be many skeletons in the closet of some low cost Skymasters out there. You will be much better off buying something that has been used frequently rather than something that hasn't been flown for years (they are out there). It sounds like you are operating from a short field so a STOL kit would be valuable. However you proceed make sure you have a thorough pre-buy inspection by a qualified Skymaster mechanic.
This thread will provide much more info about owning and buying a Skymaster
http://www.337skymaster.com/messages...ead.php?t=2190
Unread 03-26-12, 06:59 PM
SinkRate's Avatar
Smile
Herb,
Thank you for the data on the 336. Your .pdf contains what I was looking for. Certainly fits my mission profile. Is 21 gals/hr about right? What do you figure for engine reserve? I see you own the 337C, this link shows a TBO of 1500.
never mind the previous questions... I used the search function...
http://www.tcmlink.com/pdf2/SIL98-9A.pdf
Do most 336/337's make it to TBO?
Thank You Again
Unread 03-26-12, 09:19 PM
Maintained and flown right will lend at least 2000 hours. My rear engine was at 2350 when I swapped it.
I usually flight plan for 155 kts and 20 gals per hour
Unread 03-28-12, 06:57 AM
walt walt is offline
walt is an unknown quantity at this point
SE 336 performance options
I have a imaculate restored 336, new paint,leather interior, low hour remans,o time props,rewired,very high line panel(+100K) Absolutly perfect.This plane has ) time on it since completion.Feel free to call me if you would like to talk 336.My partner And I biult mirror image 336. The plane is available as an estate sale. But call just to talk 336 in general.
Walter Simendinger
631-757-7567
Long island N.Y.
Unread 03-30-12, 10:13 PM
SinkRate's Avatar
Smile Fascinating
Thank you Walt, it's a busy weekend for me, but I will come first of the week.
