Old 09-13-02, 08:19 PM
Cowl Flap Motors
I'm curuious about conditions...
Is it usually the rear motor that burns up?
If so, is it usually the older models with the mechanical cable which drive the positioning section of the switch which burns up.
If the newer ones are burning up, is it typically in conjunction with a limit switch failure?
And the real important questions...
First, tomorrow I'm headed to Singapore for a week, then headed back home through San Jose. I will arrive there (San Jose) on Sept. 21 and be there for a week. If any of our guys live in that area, I'd be happy to look 'em up and say "Hi", or maybe "I'll buy you a beer."
I'm not exactly sure what my Internet connections will be over the next couple of weeks, but I'll do my best to follow up on this.
Jim
Old 09-14-02, 11:40 AM
Guy Paris's Avatar
Cool Cowl flap motor
Jim,
I have a 77 G My rear cowl motor failed in a sense that the small rear most internal gear within the unit was rotating on the shaft. eg. not attached. It looked like it was pressed on to the shaft. Rather than try to repair it some how I opted for a new one from Cessna, $$$$$ and they wanted the core back, since I did not know if it had been left on for any length of time was the reason for changing it. I now NEVER leave the switch in the open or closed position, I place it to off. Guy.... old72driver....
